Omega 1010, low amplitude
mikepilk
I've just finished cleaning an Omega 1010 and I'm only gettting about 230° amplitude.
This is the second 1010 in my collection, and with the first one, I only got about the same amplitude.
For lubrication I used :
9010 on the balance,escape wheel and fourth wheel,
9415 on the pallet jewels,
D5 on the rest of the gear train (including the centre second pinion).
The spring looks good. All the jewels and pivots looked OK under a x10 Loupe.
Is anyone familiar with this movement and know what I've done wrong or what I should be looking for ?
I plan to have a  look at the jewels/pivots under the microscope - should have done it initially !
Well the most obvious culprit would would be a played out mainspring, otherwise it sounds like you're looking in the right places.  I'm not sure if you have already but you might want to let it run for a bit- I usually give it twenty-four hours after assembly to let the oil settle/distribute before looking for an accurate reading on amplitude.  Then I'd check the following:
  1. Cleaned and properly lubricated jewels & bushings
  2. Bent or lopsided pivots
  3. Worn bushings, broken or cracked jewel settings
  4. End shake on all wheels
With Incabloc protection you'll also want to make sure the top and bottom cap jewels on the balance haven't been swapped- they aren't always the same thickness.
Edited by RyMoeller
Spelling
D5 is kinda thick, not to mention is natural oil with a shorter life, synthetic would be better. I would use 9010 on everything that moves from the mainspring. That made a difference for me. Anyway, even 230' is plenty for the mov.t to run strong and accurate. And you also have to look at the overall pattern.
Edited by jdm
Over-oiling the pallets can reduce amplitude. I presume by spoiling the impulse.
If you have a timegrapher, how was the amplitude in vertical positions such as pendant down and pendant left?
You can live with lower amplitude as long as the escapment is well poised. If it isn't, then you'll get progressively worse positional variation as the watch winds down which could become problematic.
6 hours ago, mikepilk said:
Can too much oil (it's not sloshing around!) have so much effect?
Yes, a liberal application of oil will have an effect on amplitude.  As @clockboy stated though, in my book 230 would be acceptable- especially if I felt I may have gone a little heavy on the oil.
Edited by RyMoeller
I can live with the 230 - the watch will only get the occasional outing.
I was more interested as to why.
I've spotted one problem. The auto mechanism isn't jewelled and one of the pivot holes is oval. I can see the pivot waggling round if I manually wind it.
Are the brass bearings machined in, or pressed in replaceable parts ?
Bearings on trainwheel bridges are often a culprit for low amp? At least on Seiko. Think the Omega 1010 is about the same construction with the bushing directly in the brass . Check for excessive movement in the barrel?
Edited by rogart63
    • Thanks, ManSkirtBrew.  I started looking for a setup like yours and ran across this.  It was about half the price of the JKA Feintaster (depending on what auction you were in), and it's a Bergeon.  I bought it because I thought the price was fair (eBay - Buy it now), and I'm a sucker for vintage tools. It also has a table, so it should be easy to use for measuring jewels. I wonder if the the contact points can be changed out. Bergeon seems to manufacture new tables and accessories for the contemporary dial version. What do you guys think of it? I'm sorry this post seems to have taken a detour. I'm new here so let me know if I should start a new topic.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
