Replacement of Impulse Jewel on 1895 Elgin
I just got an 18S 7j 1985 produced Elgin Pocket Watch. The Mainspring was fully wound and the balance was spinning free. I released the Mainspring with a bench key and inserting a small screwdriver into a hole near the winding mechanism. This worked bit when I removes the Balance cock, I found that the impulse jewel was broken. 3bfd522d8e403d3b796e7a74e0d8136c.jpg628703b9c0ca9f2bef177ea42e769983.jpgc3eb5703c5d85286af37cf03f3b40dc8.jpg7cb8bc5606efec5ae2771c41b0b194a8.jpg
Now I need to remove the roller table and then remove the jewel and shellac in a new one. I will document the process with updates under this topic. Let's hope for success.
Not the easiest of repairs. Make sure you have the right type/shape of impulse pin, you will know what I mean when the old has been removed and the hole is nice and clean, careful with the length, you need it to engage in the pallet fork but you don't want it dragging. Good luck and keep us posted with your progress.
Any tips on determining the length?
Sent from my GT-N5110 using Tapatalk
Step 1 - Set up Roller Table Remover tool
Step 2. - Remove Hairspring
Step3 - Place Roller Table with Balance onto tool
Step 4 - Tighten tool onto Balance staff and align Stake over pivot (critical not to damage pivot)
Step 5 - TAP out stake and balance leaving Roller Table behind
Step 6 - Place Roller Table into Combination tool and heat to loosen old broken jewel in old shellac.
Step 7 - Clean Roller/Impulse Jewel hole in Table 6e698c3b50913cc5bab8f3ef94a7271c.jpg
Step 8 - Using Vigorous Roller Jewel Gauge, measure size of palate fork opening (was 0.46)
Step 10 - Order Jewel (or find)
More to follow........
Excellent walk through. I can't do better than that
Hi  jdrichard
if the fork opening was 0.46 I just wondered what size jewel you would fit ?
P.S. I like the zippo lighter working as a spirit lamp !
nice job  [emoji4]
I ordered a 46 given the gauge size was actually 0.467 and there was a smidgen if play when I placed the gauge into the fork. Hope I am good.
Excellent write up as always jd. :) How much play should there be between the pallet fork and the jewel? Could you measure the broken bit you removed from the roller table?
Love the digital mike...so much more finesse than the calipers.
Wife is going to Mexico next week and Xmas is done with so I look forward to my balance staff project. Your Posts have me chomping at the bit lol
Ron
Excellent write up as always jd. [emoji4] How much play should there be between the pallet fork and the jewel? Could you measure the broken bit you removed from the roller table?
Ron
Usually if you measure a 0.46 gap you would order a 0.44 jewel. But my measuring gauge accounts for this and tells you the size to order. Last time I used a wire end to measure the fork gap because I did not have the tool.
Not to stray off topic jd, but just a quick question. You have great lighting in your shots. Artificial or natural?
Also i have heard of D shaped impulse jewels is this the case of yours? and if so are they D shaped in the hole in the roller table or are they all round where they are shellacked into the table and D shaped or round above the table? The bit that was removed from the table was not sufficient to measure for diameter? or was it not a representation of the jewel size above the table. Or just not measurable?
Of course any chance I get to use the tools I have collected and restored only adds to the hobby, which I am sure you will agree...:)
Ron
The jewel is D shaped and the hole is the table is round. This is normal for American pocket watches. I did not try to measure the jewel I removed. It was too small. Best to get a gauge and measure the fork opening. I have successfully changed a jewel in a 12S 21 Jewel Illinois pocket watch.
I suppose I could answer my own questions and look at my own project...My Waltham has a D shaped hole in the roller table contrary to jd's round hole. Would not a round hole be a weak point of the jewel? When you say this is normal for American pocket watches is my 1892 model an exception or are Walthams in general an exception. My 1883 model Waltham is in storage so I can not compare. Just curious...
Can't wait to see the shellac process of installing the new jewel :)
That's why I mentioned in my previous post to make sure you have the right type, if the hole is round you need a round impulse pin, what was there before was wrong.
I'm sure your correct, but try and find one.
again amazing to see what knowledge is under the members, :Bravo:  JD
Thanks. I have used a D shaped jewel in a round hole before and have had no issues. The shellac fills the open space in the roller table hole. The geometry of the D shape impulse pin and the receiving palate fork opening is such that the back of a round impulse jewel would never touch the fork at ant time while traversing through the fork opening. Thoughts?
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
