I just got an 18S 7j 1985 produced Elgin Pocket Watch. The Mainspring was fully wound and the balance was spinning free. I released the Mainspring with a bench key and inserting a small screwdriver into a hole near the winding mechanism. This worked bit when I removes the Balance cock, I found that the impulse jewel was broken. 3bfd522d8e403d3b796e7a74e0d8136c.jpg628703b9c0ca9f2bef177ea42e769983.jpgc3eb5703c5d85286af37cf03f3b40dc8.jpg7cb8bc5606efec5ae2771c41b0b194a8.jpg
Now I need to remove the roller table and then remove the jewel and shellac in a new one. I will document the process with updates under this topic. Let's hope for success.
Not the easiest of repairs. Make sure you have the right type/shape of impulse pin, you will know what I mean when the old has been removed and the hole is nice and clean, careful with the length, you need it to engage in the pallet fork but you don't want it dragging. Good luck and keep us posted with your progress.
Any tips on determining the length?
Sent from my GT-N5110 using Tapatalk
Step 1 - Set up Roller Table Remover tool
Step 2. - Remove Hairspring
Step3 - Place Roller Table with Balance onto tool
Step 4 - Tighten tool onto Balance staff and align Stake over pivot (critical not to damage pivot)
Step 5 - TAP out stake and balance leaving Roller Table behind
Step 6 - Place Roller Table into Combination tool and heat to loosen old broken jewel in old shellac.
Step 7 - Clean Roller/Impulse Jewel hole in Table 6e698c3b50913cc5bab8f3ef94a7271c.jpg
Step 8 - Using Vigorous Roller Jewel Gauge, measure size of palate fork opening (was 0.46)
Step 10 - Order Jewel (or find)
More to follow........
Excellent walk through. I can't do better than that
Hi  jdrichard
if the fork opening was 0.46 I just wondered what size jewel you would fit ?
P.S. I like the zippo lighter working as a spirit lamp !
nice job  :)
Hi  jdrichard
nice job  [emoji4]
I ordered a 46 given the gauge size was actually 0.467 and there was a smidgen if play when I placed the gauge into the fork. Hope I am good.
Excellent write up as always jd. :) How much play should there be between the pallet fork and the jewel? Could you measure the broken bit you removed from the roller table?
Love the digital mike...so much more finesse than the calipers.
Wife is going to Mexico next week and Xmas is done with so I look forward to my balance staff project. Your Posts have me chomping at the bit lol
Ron
Excellent write up as always jd. [emoji4] How much play should there be between the pallet fork and the jewel? Could you measure the broken bit you removed from the roller table?
Ron
Usually if you measure a 0.46 gap you would order a 0.44 jewel. But my measuring gauge accounts for this and tells you the size to order. Last time I used a wire end to measure the fork gap because I did not have the tool.
Very interesting (and I also really like the use of the zippo lighter!)
Thanks. I use the lighter fluid to clean the Watches as well. Could not find a spirit lamp so had to improvise.
Not to stray off topic jd, but just a quick question. You have great lighting in your shots. Artificial or natural?
Also i have heard of D shaped impulse jewels is this the case of yours? and if so are they D shaped in the hole in the roller table or are they all round where they are shellacked into the table and D shaped or round above the table? The bit that was removed from the table was not sufficient to measure for diameter? or was it not a representation of the jewel size above the table. Or just not measurable?
Of course any chance I get to use the tools I have collected and restored only adds to the hobby, which I am sure you will agree...:)
Ron
The jewel is D shaped and the hole is the table is round. This is normal for American pocket watches. I did not try to measure the jewel I removed. It was too small. Best to get a gauge and measure the fork opening. I have successfully changed a jewel in a 12S 21 Jewel Illinois pocket watch.
I suppose I could answer my own questions and look at my own project...My Waltham has a D shaped hole in the roller table contrary to jd's round hole. Would not a round hole be a weak point of the jewel? When you say this is normal for American pocket watches is my 1892 model an exception or are Walthams in general an exception. My 1883 model Waltham is in storage so I can not compare. Just curious...
Can't wait to see the shellac process of installing the new jewel :)
That's why I mentioned in my previous post to make sure you have the right type, if the hole is round you need a round impulse pin, what was there before was wrong.
Edited by oldhippy
I'm sure your correct, but try and find one.
again amazing to see what knowledge is under the members, :Bravo:  JD
Thanks. I have used a D shaped jewel in a round hole before and have had no issues. The shellac fills the open space in the roller table hole. The geometry of the D shape impulse pin and the receiving palate fork opening is such that the back of a round impulse jewel would never touch the fork at ant time while traversing through the fork opening. Thoughts?
Have yo ever heard the term fitting a round peg into a square hole.:biggrin:
Fitting half a round peg into a square hole. Do you have a source for round impulse jewels?
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
