Case back opener
Not posted for a while so I hope you can forgive the question.
Can any kind soul suggest a good case back opener for press on backs, just broken my current one  and want something better sub £100 hopefully.
One that can get bezels off as well may be handy.
Thank you.
Jon
4 hours ago, TheFixer said:
Thanks gents looking into it.
This may fit the bill.
BERGEON-4932-WATCHMAKERS-WATCH-CASE-BACK-OPENER-OPENING-TOOL-WATCHES-HK4932
I use this and find it excellent - the edge of the blade is quite blunt, so it reduces the risk of injury, but it is good enough to open most cases (especially if there is a groove/ recess) - You could always sharpen it anyway but I found it was perfectly fine as is.
you place the edge of the scoop in the gap and twist instead of pry open. I have had a lot of success with this type and it avoids the blade to slip out dangerously when it slips. It is not the only one I use, but I like it very much
    • If you're seeking advice for your "Harvard GSD" MArch II application essays, I'd recommend taking a thoughtful approach. Reflect deeply on your experiences, passions, and goals, and tailor your essays to showcase your unique perspective and potential contributions to the program. As for resources, I recently stumbled upon a gret platform for essays, and I must say, it's been quite helpful. Their selection of pre-written essays covers a wide range of topics, and their professional writers can also assist with custom essays tailored to your specific needs. Check out their offerings here: https://essaypro.com/essays-for-sale. Remember, authenticity is key in your application essays. Good luck!
    • For clarity and ease of testing, I redid that diagram, flipping the circuit to match the layout of the physical watch.
    • Hello, Thanks for the reply. The old jewel will get pushed out from the "outside" which is the dial side. The new jewel will get pressed in from the inside (shown below) which is the movement side, correct?     And the old jewel and spring will get pushed from the is the "outside" which is the dial side. Thank you very much for the information. I will take out the KIF spring and save it. Will update when the new jewel is in place!   Regards, Joe
    • It's a little circlip style retaining clip to keep the pinion from riding up out of position.
