I recently was buffing up a watch case (fake rolex, gift) and the stainless steel ground down to a pinkish metal. And thoughts on what is happening here?
Sounds like you have buffed through plating not stainless steel.  It will probably be copper plating showing and if you keep going it will probably be brass.
Copper plate is often used as an intermediate layer before other more difficult plating materials. For the faker, making all your blanks in brass means you can use the same part for a steel effect or a gold effect.
Yours is probably nickel plated. If you want to try some fun chemistry then you can buy nickle plating solution on the internet. If it works then great, if it doesn't, then one more fake can be consigned to the scrap bin :)
316~L is used with the higher end replica watches, and the super replica watches are currently being planned to be built using 904 stainless steel, especially the Rolex models, and prices will be over $1000 per replica watch..
Edited by SSTEEL
Yours is probably nickel plated. If you want to try some fun chemistry then you can buy nickle plating solution on the internet. If it works then great, if it doesn't, then one more fake can be consigned to the scrap bin [emoji4]
Thanks for the advice. What about chrome? It was invented and used in pocket watches starting in the 20ies and 30ies. I have an aluminum guitar that was chromed and they had to add Zinc, Copper and then chrome.e2bcf99fb9d48fe6ae4e8b1a1c1db4e2.jpg
Sent from my GT-N5110 using Tapatalk
Sorry if this is going a little off topic... The zinc is required because the surface of the aluminium oxidizes as soon as it's exposed to the air. Copper adheres nicely to the zinc and the chrome.  As aluminium is relatively soft and chrome hard, this combination is still susceptible to cracking and flaking of the chrome, so treat with care.
Build buy a guy who does Motorcycle parts. Should endure. Should do watch cases the same way.
OMG....they make electric guitars out of aluminum...never seen one.
I have a resonator, but nothing like this.
fascinating.
fascinating.
Great guitar, plays exceptionally well
