Freebies Again....
And Again....:biggrin:
I went to Tip Top's site to look for a tension ring crystal again . I wanted to order 3 successive sizes , 31.3 , 31.4 , and 31.5 . The site showed all three as sold out . I contacted Steve from TipTop and asked if they were going to get any more .
He returned my message and said that he had them but the packages were opened and he didn't list or sell open packages . He also said that he had those sizes in a brand he didn't advertise .  He continued and told me that he found 2 of the three sizes I was looking for unopened and updated his site to list them , and If I bought both of them he would also throw in a few opened packages and the 3 sizes I was looking for in the brand he didn't advertise ....So I bought the 2 at $4.95 each and with shipping it came out to $11.51  after he gave me another $.99 discount .
HAPPY NEW YEAR TO ME....:woohoo-jumping-smiley-emoticon:
Anyone now how the Evertite crystals look? Are they a flat top crystal as in the drawing?
Trying to find a crystal for my Dugena chrono? Tried a normal ACT Sternkruez crystal but think it's so thin? Looks almost the same but would like something more like a diver crystal? Thicker at the top? Sternkreuz crystals only goes up to 34,9 and i need a 35,5 or 35,6.
Hi rogart63 .
The evertite  is not a true flattop , but it's not domed either . It is a tension ring crystal with a rounded edge comfortably turning up to the top . If you are wondering if it crowds the hands , I have not ever had that problem , even with block indexes that stand a little higher .
It is acrylic , not glass . I wouldn't call it thin , but certainly not as thick as a glass diver crystal .
9 hours ago, ricardopalamino said:
Hi rogart63 .
That profile look perfect. I had contact with tiptop and see if he could get me a 35,6 mm crystal?
Was the shipping okay? Doesn't get any answer from Steve if he had a 35,6 evertite crystal. Saw that Esslinger had them but costing $15 bucks in .
Is it better to contact via the site or by email? I am keen to try a evertite crystal.
Saw that GS supplies  http://www.gssupplies.com/ Do Costum crystals if i can't find any that fit my watch.
Steve at TT crystals will probably get back to you . Yes , the shipping is reasonable . I looked on the site for the size you are looking for and it said Sold out on both the white and yellow tension ting , but contact Steve from the website anyway .
I think the evertite are about $4.95 .
I just got 2 crystals from him,  and the site said sold out , but he found some . I paid for 2 and he sent me 10 , and gave me a discount .
COntacted him again and i will see if he answer. Have a certian taht need a new crystal and a few others.
I'm very pleased to say that Tip Top Crystals came through again...
I wanted to order a crystal for a Seiko Bellmatic and saw on the web site that they were sold out . I contacted Steve and he told me that all of those crystals and some other Seiko crystals were bought up by a watch maker that specialized in Seikos .
Alina crystals is in the same building and he was kind enough to find out that she had what I was looking for and asked her to send me an invoice . Steve also suggested 3 other crystals that would fit the bellmatic and I bought those . He went so far as to combine the shipping of the crystals from both companies so I would only have to pay for 1 order , AND he sent me 5 free extra spare crystals to boot .
Thank You Steve @ Tip Top Crystals......:Bravo:
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
