I've serviced several clocks before, but this is the first watch I've done.
The photo below shows the mainspring next to the barrel, the spring to my unskilled eyes looks to be slightly set and I'm wondering should I replace it?
Am I correct should the spring be replaced, or is this still ok? Appreciate some advice.
Thanks
Tony
Honestly I can't tell by the "look" if it needs to be replaced.  I've tried and failed in the past.  The older blued steel springs will appear set simply because they don't have the S turn that new mainsprings have.
I usually decide on replacements based on the following:
  1. Is the old one broken?
  2. Is a replacement available?
  3. How long will it take to remove the old one if I reuse it and discover it's got no life left?
  4. How long will it take for my supplier to get the new one to me?
  5. How much money do I have to spend?
  6. Will I have to pay $10 shipping for a $15 mainspring?
(Obviously none of this is helpful but at least you know the internet still works)
Edited by RyMoeller
Grammar
That spring still carries its shape, so I think its alright and carry on with it. The coils have good distance between each other, they don't look tired its not out of shape so I think its fine.
Having seen people repair clocks before I'm always amazed that if this was a clock spring they would be extremely happy. Clock springs can look set at least from a watch point of view and still be very very acceptable.
Visually you can't tell by looking at the mainspring and you can't even go by the lack of the S-curve of the modern spring. I've seen blue springs original American factory springs have S-curve's and I've even seen some of the new White Springs look partially set visually you can't tell just by looking at it.
Then whose watch is this? In other words if you're doing this for a paying customer you would change the mainspring especially if it's blue. but if this is your personal watch I probably wouldn't worry about it.
There is a way to figure out if this is going to be a problem which is you put the watch back together with the spring. depending upon how badly set the spring is and whether it's even a functional spring at all will determine the running time of the watch and the amplitude. The amplitude will really be a problem at the end of 24 hours if you just don't have enough power to run the watch.
that spring looks good.  kinks or rust are the things to watch for.  i came across a " lifetime main spring"  basically just twice as strong.  any one know about these ?  vinn
And did you installed it or just saw on a catalogue?
I'm curious about the twice as strong part? Was it actually printed on the package it's twice as strong where did that come from? the reason why I'm curious about twice as strong is increasing the strength of the mainspring it changes the amplitude of the watch. Quite a few watches if you put a double strength mainspring in you'd have too much amplitude which would be a problem. Then conceivably if this was a replacement spring for generic watch twice the strength would be thicker you would lose length which would cause a loss of running time so I assume this was a very specific watch?
There are watches that come with barrels that are sealed with the claim that there a lifetime or something equivalent. But I don't think watch companies ever grasped that lifetime for the watch could literally be hundreds of years.
So the early blued steel Springs they had a habit of breaking. Not necessarily the blued steel fault I suspect some of its from manufacturing. They break in a variety of locations the most interesting one is when the spring literally shatters into a whole bunch of pieces.
So right now I'm looking at the various labeling from a variety of mainspring envelopes common terms are unbreakable & non-setting  both quite common and one package even says guaranteed for the life of the watch.
keep looking.   i bought  a  17 J elgin pocket watch for the mvt..  it was stiff to wind, but ran good.  after taking it out of the barrel,  my watchmaker friend ( bill)   said " its a lifetime spring "   put it back in.  vinn
If the spring isn't the old blue type and appears to be of the new type white metal it can be referred to as a lifetime spring also known as an unbreakable spring, depends on the manufactured label. But as you know all springs can and will break.
The Elgin mainspring is a  Durapower Mainspring. to understand the Elgin mainspring I'm attaching a PDF.
So Elgin had their own special alloy other companies had other things the modern spring have similar characteristics to this. It's why they say their lifetime never do a whole variety of evil or bad things but they can still do those things. I've still seen modern white spring broken even set which of course from the literature is totally impossible.
So even though Elgin is specifically describing their modern nifty steel it still applies to the modern Springs. Basically the modern steel is stronger the same thickness.  This can be a problem though for older watches specifically designed to run with a blue spring the new white spring may have too much strength you will have over amplitude problems.
Elgin Durapower Mainspring.PDF
I think watchmakers' lore says this happens during a powerful thunderstorm. Who knows.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
