I wonder if I can ask for opinions / advice on eyeglasses and lighting please.
Being relatively new to watch repairing as a hobby I've relied on a relatively cheap headband eyeglass obtained via ebay plus a bright desk lamp I already had. The eyeglass is meant to be 15x but I suspect is nearer 10x; I don't know if this is OTT magnification but I get on well with it.
As I'm doing more close up work I think I should invest in something a little better if only to ensure I don't get eyestrain. I've looked at Cousins - https://www.cousinsuk.com/category/eyeglasses-magnifiers-loupes-loupe-chains - and there is a rather large array though! I did search through the forum and came across http://www.watchrepairtalk.com/topic/748-handy-clip-on-dual-loupe/ which is something different altogether. Maybe there are other options I'm not even aware of.
In terms of lighting I can find as I get to a really fiddly bit of repair where I need to lean in very close I inevitably cast an annoying shadow .... but that might just be practice and technique in where I position my head and hands as I get to the more fiddly bits. Alternatively there might be some great lighting option I'm unaware of.
So can any of you offer advice on what eyeglass (or glasses) I should get from Cousins (or elsewhere) bearing in mind I'm not a pro ... and also whether I need to consider a more appropriate light source.
Many thanks.
For lighting I would recommend a watchmakers light. http://www.esslinger.com/dazor-30w-fluorescent-clamp-base-task-light/
Although a  little more expensive, it will be worth the money. A few weeks ago I came across a very nice ledlight which can be dimmed with a touch of the hand, also you can adjust the colortemp from coldblue to warmyellow and all in between in small steps. It was only 25 euro but I like the features and the fact it does not get warm
http://spotlightelectronics.com/reviews/review-livarno-lux-led-desk-lamp/
See also the thread about loupes which Will opened.
Edited by Watchtime
type errors
Firstly unless you're working on particularly small movements (such as ladies watches) 5× magnification should be sufficient for general work. Fine or fiddly work 10x magnification should do. Anymore than that your head will be so close you will find it very difficult.
As for lighting:- see pics of my scruffy old hobby roombf175822ccd835c38dbadd9d991d4850.jpg664842660d9e28a0df247255e126ae6e.jpg
Sent from my SM-T585 using Tapatalk
What I had when I was working eye glasses from a 5 down to a 2 the 3½ being the one I used most.
Lighting on my bench I had something like the picture. I also had many strip lights on the ceiling and around the workshop some at waste high, other lights over machines such as lathes. With lighting make sure if you are close up the light doesn't get hot and make sure they don't cast a shadow.
the dentist  usually has the best type of available magnification and lighting.  i go to an opthomalogist (not optomitrist)  every year.  and don't get eye strain.
Great advice as always - thanks.
The first thing I'm taking away from this is that my one eyeglass is too high a magnification! Even if its advertised 15x is probably nearer 10x I'm still two or three times over the magnification you experts use. So that's a shopping trip via Cousins today!
Good advice on the lighting too. Maybe down the road I'll go for a pro bench light but I like the sound of Watchtime's cost effective LED lamp as this can angle in both the vertical and horizontal planes. My standard desk lamp only directs light downwards in a fairly concentrated beam which is why I probably have issues. I've bought one on Amazon!
Better general lighting as suggested by digginstony and oldhippy is also where I'll concentrate some effort as the soft glow lighting in the dining room where I do most of my watch work will get a makeover with some 100W+ bulbs!
Best is to have overall good light and more concentrated light on thw workbench. It is less tiring for the eyes. The swivel of the lamp I mentioned, in all directions...is a big advantage. I was lucky to have 2 orginal watchmakers lights in a heritage I bought, but the swifel lights do a perfect job also.
You need to check the focal length of the eyeglasses. The "magnification" is often meaningless.
Very good point you made about focal point and totally agree with you. I use a head band with pull out magnifiers. As can be seen from photo. The magnifier can be placed on different positions on the mounting bridge which alters the point of focus. I personally use 5x magnification for general work and 8x magnification for the small tricky stuff.a7bdd3874997ad37b8cd752dacac7244.jpg
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
