Cheers mates..
Have just cleaned and oiled and put toghter an ETA 2872 yesterday. The movment started just fine , but after a while it started to run like h......it when like 5 min gain in one hour.
And when I tried to adjust it with the speed stud while I had in he timegrapher, I did not get any change, nor either when I tried to adjust the beat error stud.
The timegrapher just show dots all over the screen, and sometimes the timegrapher did not show the imput on the screen, but I can hear the beat sound from the watch all the time. ( have tried it with other watches, so there is no error with the timegrapher)
Where to start adressing the problems???   Help!!
Have a look at the hair spring with a loupe. With that level of gain the odds are that you have a couple of coils sticking together, either due to magnetism or oil residue. Alternatively make sure that the hair spring isn't hitched up on anything and that it isn't touching anything that it shouldn't.
Thanks Marc, I will check later on today....
Hey Marc, Got some time yesterday, and looked at the hair spring with a microscop, (bought a new lomg arm stereo microscope)
could not see anything strange with the hair spring, is there anything else that I could check out?? still going fast as h........
Kind
Armand
Hi Armand,
Unless you have swapped any parts out from a different movement there are really only 2 possible causes for the excessive rate, one is the hair spring, and the other is the main spring.
If too powerful a main spring has been installed then over-banking can occur. This is when the amplitude of the balance wheel is so great that the impulse pin impacts against the outside of the pallet fork at the extreme ends of its oscillation and bounces back with greater energy as a result. This will result in an indecipherable timegrapher trace and can often lead to an increase in rate. Probably the easiest way to diagnose this is simply to listen to the watch. Over-banking is often referred to as "galloping" and if you listen to a watch that is doing this it is clear why; the regular ticking sound is replaced by a galloping horse sound. Another test to see if the main spring is too strong is to let the power down completely so that the balance stops and then just put on enough winds to start it going again and no more. If you get an acceptable rate with just the minimum of power then try increasing the level of wind incrementally, observing the behaviour of the balance at each stage. If the main spring is too powerful then at some point before you reach full wind the over-banking will start and the trace will go snow storm again and the rate will probably go through the roof.
I'm not sure that this is your problem though because in your original post you mentioned that it was fine to start with before going haywire. If it was a main spring issue I would have expected it to be a problem from the start.
The other possible cause is of course the hair spring. If anything happens that effectively shortens the hair spring then the rate will increase. This can be down to contaminated coils sticking together, magnetised coils sticking together, the outer coil getting hitched up on the regulator arm, an out of flat or out of parallel hair spring making contact with the under side of the cock or the top of the balance wheel, etc.
In my experience this is the most likely cause by far, which is why I suggested it to start with. Have you tried demagnetising the watch? With the watch running observe as much of the hair spring as possible to check that no part of it is touching anywhere it shouldn't as it breaths.
There are two other possible causes that could result in mad high rates. One is that with a screwed balance, screws have been removed from the balance rim and not replaced resulting in the balance being too light. This would give you an increase rate but you should still get a timegrapher picture. As the 2872 doesn't have a screwed balance you can discount this as an explanation.
The other is that the 2872 is the 28000bph twin of the 2873 which runs at 21600bph. If some 2872 train wheels had been swapped for 2873 train wheels then you would also get a crazy high rate. However, you would still get a t/g picture and the rate error wouldn't show on the trace, in fact the trace would look normal but the hands would move too fast. Again, the problem would be there from the start.
I'm pretty certain that you issues lie with the hair spring / balance wheel.
Marc
On 7.10.2016 at 2:30 PM, Marc said:
Hi Armand,
Marc
Hi Marc,
First of all, sorry for very late answer. I have been lot of other thing ta take care of...building on to the house, prepering the garden for winter and stuff...
Thanks for doint this for me, Im very gratfull... Very good decription to how to try to solve problem. I had some time to work on this watch in the weekend.
When I did service on this watch, the original main spring was broken, so I got I new on from a this company http://www.elisabeth9679.com/
I have no reason to belive that the spring is the wrong type, but that can of course be the case. Anyway, a put this in. And it when well like I said befor for some weeks after that like I wrote before...
I have not demagnetising the watch, and in the weekend I was looking at the watch while it was running, and I noticed that some of the spring coils was going togheter like you said. I took the apart. Winded uo the watch, not 100% but maybe 70 / 80 % hard to tell ...and had on my hand, then it when okay, for 2 hours., and then it started to go faster...the day after I looked at the coil spring, and they where still apart...What is happining???  Can it be magnetized while running??   Later on this day ore tomorrow I will wind it up 10 % and measure on the timegrapher, and see if there is a variation if I wind some more....
Thanks again
Armand
51 minutes ago, clockboy said:
It could be some sort of grease on the coils. If the coils stick together for any reason the watch will run fast.
Can that be like that the watch runs okay for 2 hours, and the start to go faster?  I thinking the main spring will drive the movment with a constant speed, and the balance wheel is the regulator, and if the the spring coils are sticking the movment goes faster. But if the spring coils are not touching the other it should be okay. It douse not matter how long the distance is as long there is air between them or?
My advice: Put a cheap compass close to the ticking watch. If the ticking watch makes the compass needle sway back and forth, the hairspring is definitely magnetized. If the compass needle does not sway, no firm conclusion can be made.
In your last post I understood that some of the coils were sticking together. I was therefore wondering if it was grease causing this issue. If I have read your post correctly that is. If so how did you overcome the coils sticking together. If you are absolutely sure it is not the hairspring  I would then measure the strength of the old spring to check it is comparable with the new. I know that it is a pain to remove the new spring but it is a case of elimination.
If it is not the hairspring & not the mainspring then it must be the canon pinion.
About the main spring, so was the old one broken almost ine the nearby with the arbor, but how can we explain that it runs okay the first 2 hours or so, and then start gaining speed....
Pls explain what it is, if its the canon pinion?
If the canon pinion is loose then the watch will run fast & it will be impossible to regulate. If the hands have no resistance & feel very loose when you turn the crown it is almost certainly the canon.
The mainspring for a 2872 is GR 3315X
1.30x.12x400x10.5
Sorry, how and why a watch could run fast with lose/slipping cannon pinion ?
Edited by jdm
The cannon pinion operates like a clutch. It must have enough friction to drive the hands but not to much to stop the watch. Also if very loose the movement will be very difficult to control & also the hands do not turn.
However I have worked on watches where the cannon was too loose & the hands were still turning.
See below an explanation of how the cannon pinion works & how the friction is adjusted.
http://www.timezone.com/2002/09/16/the-motion-works/
Cheers mates!!
Sorry for late answer...
Thanks all for great help from you all !!
I will take out the canon pinion during the weekend, and see how it looks...
to be continued ...
  • Similar Content
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
