Staking Table will not lock
jdrichard
Turn that screw underneath, it should improve the situation.
(the larger one in the center, not the small one)
Been working it and oiling it, however, I still need to tap the underneath of the table to unstick the table after I tighten and loosen the table.
I think the one on the right is for picking the stake out of the box. That other one looks home made it doesn't match the others. About locking, have you unscrewed it all and cleaned it all out?
Yes I have cleaned it. I adjusted the big screw on the bottom after oiling the hole and I can loosed the table by tapping the edge with a screwdriver. Then I align the hole and and turn the knob at the back to rotate the internal cam, and it does lock. The problem is that when I loosen the knob and thus the cam, the table only loosens slightly and I need to knock it again with a screwdriver to free it up. Would love a cutaway of the stacking tool. Any suggestions. May be internal corrosion.
the table should come right off when the screw is removed, and the knob pulled out. Maybe you have corrosion or gunk under there...
I can't actually pull the screw out after removing the bottom 2 screws. It seems to jam. But what you are saying is that once I pull the rod out the back. The table should lift straight off, correct?
Jdrichard,
The table locking mechanism is a crankshaft type of cam similar to the mechanism used to lock in the head and tail stocks of watchmaker lathes. These mechanisms can become worn with use and may require some machining techniques to bring them back to working order. To isolate the problem place a small shim (tin foil) between the locking cam and the hole in the shaft that pulls the plate down. If it now locks then that is the problem. To fix you will have to build back the cam or the hole.
david
Update on seized staking set. Took out the locking screw and loosened the cam shaft and then knocked out the shaft with a small hammer (scratched the nickel plating on the side a bit, but it needed convincing). Then I removed the table by knocking it with a punch from the bottom. The complete lot fell out. Then I took 1200 grit sandpaper and sanded the hole where the locking cam fits . Did a bit of this as there always some corrosion. Lastly I cleaned the table in lighter fluid and then alcohol and then I re-oiled once dry. Reassembled it and it works like a charm. Loose until I turn the back dial and then tight. Then turn the dial again and the table is once again loose.
Thanks guys for the help and suggestions. I am operational and will be knocking on the balance and roller table once I get the right jewel for a 21 J Illinois PW I have been working on. I am in deep now and have a jeweling set coming in the mail next week. Seitz full set.https://vimeo.com/183234528
    • Walked by my local jeweler today and asked if I could dig around in his old watch case, and picked this guy up (along with a cool vintage compass and a Seiko kinetic5M62). My girlfriend's son asked if he could borrow one of my pocket watches for prom, so I thought if I can get this guy running it'd be a nice prom gift. Non-running. Felt like the balance was overbanked, but it turns out the train was jammed solid. Looks like it was just dried lubricant gluing the 3rd wheel in place, because it's clean as a whistle otherwise. Parts are in the ultrasonic right now.
    • Neverenoughwatches. I did read your experience with the basket. I did try to file mine to true it up..but I couldn't find the sweet spot. I figured I would just bite the bullet and get the Elma components.   Thanks Randy
    • My mentor has been using one of the Chinese clones for several years. Seems to work very well. Just put the object you wish to demagnetize in the centre of the cross and press the button. One word of caution though, the quality and QC of Chinese clones can vary a lot. You'll never know whether you got a gem or a lemon.
    • You could also use a very fine artist's brush to brush between the coils.  If you get a size 00 or even 000 that should be small enough for convenience, and with bristles so fine that they are incapable of damaging the hairspring.  Get a good one though, like Windsor-Newton or similar.  I have never had a Windsor-Newton brush shed on my art or other work.  You want a soft brush that will not shed.
    • Sounds interesting but how do you push the button if you’re holding both ends? the large current draw overheats after 3-5 seconds and the thermister triggers. A great tool for magnetizing things but I’ve not be able to ever demag anything with it because the emf is so strong it pulls the item off center (down or up).   I paid $89 bucks for it from  CAS-KER, if someone on the board wants it I’d gladly sell it for $25 plus shipping (probably US only otherwise postal costs are prohibitive). Just sent me a note offline.
