needle files
rogart63
Looking for some small needle files. Square or at least one surface flat? 1,5 mm would be nice i think . And the i should do a slot in 1 mm?
Trying to do a little puller. From a M4 screw.
Could i harden a M4 insex screw to make it harder to wear out.
For small tools, I often draw on my days doing scale model aircraft and go the stores specializing in this craft like these places:
https://www.megahobby.com/categories/tools-supplies.html
http://www.micromark.com
http://www.hobbyking.com/hobbyking/store/__953__178__Tools_Bags_Storage-Knives_Cutting.html
We are spoiled to have an incredible tool store in Ottawa, Lee Valley Tools, they ship internationally.
You might want to see if they have what you are looking for:
http://www.leevalley.com/default.aspx?c=0
The founder (passed away recently) was absolutely passionate about tools, and even teamed up with a local surgeon to create better surgical instruments, that should tell you just how capable Leonard Lee was as a toolmaker.
I had the privilege (and I don't use that word very often) to meet Mr. Lee once in his store and asked him a few questions about a product, an absolute encyclopedia of knowledge on tools.
Every tool or product I bought from that store went above and beyond what I expected.
If you see something on the Lee Valley site, buy it. If it fails, they will take it back no questions asked.
Edited by MilTimeCan
typo
23 minutes ago, szbalogh said:
There are watches with day and date complications :thumbsu:
I don't have a watch. The day I gave up watch and clock making I haven't worn a watch. Its only about two years ago I decided to buy a few clocks. My sister thinks I'm odd. I don't even have a television.
We neither watch TV now for about 10 years. Last time we put the antenna in the PC to watch TV... the soccer euro championship :) But 2-3 times a year we watch a fayritale DVD with the kids on the old CRT. They were born in the LED era :)
Not to be OFF.
What do You think of Degussit midget files? The 50x3x0.3 mm pice would be an ideal pivot grinder. Are there any substitutes to the Degussit? How long does it last if one is grinding hardened steel with it? Its not expensive at Cousines UK, the question is how many to order? And how about the other bigger ones? Are they important to have?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
