Superior Knowledge Required
I've just rebuilt a movement using a donor movement. It's the same Cal. P 320 as the original, but I need a removed second hand, so had to replace the wheel with the one from the original, with the extended pivot.
The problem is, the new movement has cap jewels for the train wheels, and the donated wheel shaft is too long. It jams if I tighten the cap plate up.
At the moment, I've left the cap jewel off, and it runs fine, but has a lot of end shake. I feel I need to shorten the pivot a little.
The question? Is that the correct way to go about it? If it is, how do I measure it, and how do I shorten it. If it's not the right thing to do, what is?
The picture is of the actual watch, from the auction.
A diamond file should be fine, followed by buffing stick. I would consider investing a micrometer to see how much are you knocking off.
EDIT: mine is not superior knowledge. Just honest advice based on experience and common sense,
Edited by jdm
So, I measure the wheel that fits, end of pivot to end of pivot, then shorten the other one to the same length? I have half a dozen micrometers, so no problem there.
How would I hold it? Tweezers? I'm thinking it must be incredibly easy to break it off.
Not looking for superior knowledge overall, just superior to mine.
Edited by ftwizard
Send me one then :)
Quote
What about the wheel over an holed small block, hold it down flat with an ice cream stick and caress the pivot with the file.
Edited by jdm
26 minutes ago, jdm said:
"Send me one then" :)
Yeah I know. I went through a phase of collecting old Starrett and Moore & Wright instruments, so I have a few.
"What about the wheel over an holed small block, hold it down flat with an ice cream stick and caress the pivot with the file"
I think this would be the best idea. I'm sure it would snap off without support.
Edited by ftwizard
38 minutes ago, clockboy said:
Is it possible to change the jewel. If so this would be the best & easiest solution.
What do you mean? That doesn't sound that easy to me.
Do you mean move the jewel? Is that possible?
What if I shimmed the cap jewel plate?
Edited by ftwizard
Ebay search for another movement mate, not being funny but going at it with a file etc there is a massive chance of snapping the pivot, then if you manage to file it down to the correct length you will need to dress the end you have filed otherwise it will run like bag of nails against that jewel.
What's being said so far is possible to do, as for holding it with tweezers id steady it with tweezers and maybe stick it in some pith. The pivots are very hard but extremely brittle so go very carefully if you go ahead without another movement to hand.
I haven't measured yet, but if I loosen the cap screw by one turn, it's enough to free the wheels.
Also, I think the bottom jewel could move down a little without causing any problems. It's just a matter of the best way to do it with limited tools.
Edited by ftwizard
 Adjusting pivot lenght (endshake) is done by trial and error, file down a bit and then try it.... until it has no endshake but spinning freely.
Pivots are shortened (and polished thereafter) on a Jackot tool or on a dedicated pivot polishing tool:
I hope you are dong this move it with a jeweling tool. You must move the jewel precisely so if the wheel teeth no longer mesh to can put the jewel back to where it was originally. What I have read it seems that the pivot is only a fraction too long. If so you can hone the pivot down BUT use the correct tools either a lathe or a jacot tool & hone it down gradually. However if the set up is the same as the second pic below my original suggestion is the best because if it does not work no un-reversable damage has been done. But again use a jeweling tool & measure the pivot with the tool below. This is a relatively simple job providing you use the correct tools. If you have not got the correct tools I suggest you purchase another bridge.
Also see below a pic of the two types of pivot/jewel set up so you can see what you are trying to achieve.Screen Shot 2016-08-19 at 07.42.30.png
Pivot measuring tool.
Ftwizard,
If the original staff wasn't binding and running then its pivot is probably the correct length. I would first measure the original staff and compare it to the replacement staff. If the pivot on the  replacement staff it too long then it will need to be shortened. This is done with a Jacot Tool (using the lantern) and a burnisher. If you go Youtube and pull up a Steffen Pahlow video called "MAKING A GLASUTTE BALANCE STAFF",  you can see how the pivot end is filed down on a Jacot Tool. There are also many watch repair books that cover this subject.
david
    • Interesting, but not very accurate, unfortunately. Using the word "Radiation" without specifying the specific type of radiation [what is being radiated] is one of the commonest mistakes - and most confusing to non-technical people.  Also, I believe the commonest lume in general use nowadays is just a phosphor compound that is "charged" be exposure to light? I've never personally see a watch with tritium lume, and it's not something I would particularly want as the decay is quite rapid with a half life around 12.5 years. Tritium is also of course radioactive, emitting beta particles, and it can possibly cause cancer if ingested!   Re. geiger counters, it's also important to note that many on internet sites are fakes that detect RF rather than, or as well as, ionising radiation. Or just low quality that likely only detect gamma, or gamma and alpha. Only high quality mica window GM tubes will detect beta; all the cheap geiger counters I can see on on ebay at present that show the tubes, use glass or quartz - despite claiming to detect beta
    • Some things that we think of as relatively new or modern have been  around for a very long time. Alloy mainsprings, balance wheels and hairsprings and epilame for example were developed over 80 years ago. I use clear nail varnish for glueing crowns on, as well using it when making fibre bristle oilers and tweeking tools, its easy to apply if you get a move on after taking it out of the bottle and sets nice and hard.
    • Hi you will probably find there are a few citizen movements the same or close due to manufacturing processes.
    • Hello, How do I open a screw back cover on a hidden lug watch? It is perfectly round and rotates in the watch holder.   Thanks!
    • Where abouts north east chief ?
