I'm relatively new to mechanical watches and have quickly become fascinated but have an elementary level question that hopefully someone can answer.
If the hairspring and balance wheel come to a complete stop due to the main spring running out of power, what is it about winding that sets the balance wheel back into motion?  I understand the way the escapement works once it is in motion to input a small amount of energy into the balance wheel, but don't understand how winding alone sets it back into motion.  I know with grandfather clocks you have to restart the pendulum manually and I'm wondering why this isn't the case for watches also. TIA.
The power from the mainspring is transferred through the train wheels but this energy is released under the control of the escape pallets. This an old vid but explains it better than I can.
you may have noticed,  when the main spring is totaly  wound down,  3  or 4  turns of the crown will start it running. .with out shaking !  if it dosent you need to go to work on it or perhaps it a cheep watch     welcome to the forum,  vinn
Thanks for the responses.  So it seems that when the hairspring and balance wheel stop, the chamfer of one of the pallets is able to be engaged by a tooth on the escape wheel, and once the main spring has been wound a few turns it has enough energy to allow the escape wheel to set the balance wheel and hair spring back into motion.
Don't forget there could be many reasons why this might not happen. You should expect this in a well serviced watch, even with a new mechanical watch, dirt is the main reason why a watch stops, gummed up oil is another and wear so unless the movement is squeaky clean don't expect it with every mechanical watch.
  • 4 months later...
Yes. As the power runs down, eventually the balance amplitude reduces to almost nothing, but its neutral position with no power is with the roller jewel in the middle of the pallet fork horns, with the pallet fork centred. In this position, the pallet jewel angled face rests against the face of a tooth on the escape wheel, and a little torque on the escape wheel will push the pallet fork away setting the watch in motion.
When the roller jewel is disengaged from the pallet horns, the pallet lever mechanism is essentially bistable and should flick to one side or the other where the pallet jewels just lock the lever in place. For this reason, it is important to set the hairsping on the balance wheel so that in its neutral position it would hold the roller jewel in the centre of the horns as described above, otherwise (amongst other problems), it will be necessary to shake the watch to move the balance and set it in motion.
in practice the neutral position is best tested with the watch in motion. A timing machine can listen to the noises the escapement makes and reports any misalignment as a "beat" error. This is resolved by rotating the hairsping attachment (collet) to the balance or to the balance cock, depending on the watch.
  • Similar Content
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
