Identification please
buzz12
Found this movement in a sealed bag and would like to learn more about what it is exactly? It appears to have been repaired/serviced and cleaned but not sure if it is complete or if it works.  I have not spotted any makers marks so any information about the movement (age, possible origin/maker etc.) would be gratefully received.
it is a new one for me. By looking at the mainspring barrels it is some sort of Fusee driven clock & therefore vintage. The the pendulum is missing. & I can not make out where the fusee chain goes.It might be driven by weights.
Oldhippy will be the guy that might be able to give a better description.
Looks like an old long case movement circa 1860. The barrels are not fusee as they are not tapered.  They are scrolled to receive the gut cords that the weights hang on.  One for the clock and the other for the chimes.
It is a 8day 5 pillar Longcase Clock, known as a Grandfather Clock. It has rack striking and an anchor escapement. The movement is almost  complete, its missing the bell and nut, two pulleys, pendulum, dial, hands, seat board, screws to hold the movement to the seat board and case. A five pillar movement puts it above  as just being ordinary. One other thing about this one is the escapement is set quite low down the train. It has been repaired in the past as you can see on the inside plate for the pallets, this was undertaken a very long time ago as you can see by the colour  the brass matches.   The makers name would have been on the dial. We can still put a date to the movement by looking at the pillars and they tell me 1660 to about 1740 and it most likely had a brass dial, I can't see all of the hour wheel pipe but what I don't see is a pin or a protruding type pin so this tells me it didn't have a calendar therefore I expect the brass dial would be 12inch square. The movement has recently been cleaned and the screws polished.
I he ain't at all bad is he he's a wealth of important information. Although I'm amazed  he can remember anything with a name like oldhippy all those psychedelic drugs an all :D
I'm not that good because I forgot to mention that the bell post and screw is missing. It would be screw into the hole just above the pallet cock to the right. The proper term for the strike is called rack and snail. I'm off to bed to give my little gray cells a good rest.
That's amazing Oldhippy!
They might not all be missing... somewhere among the stuff I have, I have seen most of what you mention. I will have a dig about tomorrow and see what I can find.
I have seen a brass dial with brass spandrels about that size.  Various pendulums (one I am sure is from the single handed grandfather clock I have, but not sure which one).  I'll put some pics up and see if they may go with this movement.
Can't thank you enough OH for sharing your invaluable knowledge. I figured from the workmanship that it was old, but didn't realise it was that old. Pics to follow and we'll see if I have a full house:biggrin:
Found some dial bits but they are not the right size. Is the first brass dial the sort of thing that the movement would of had?
I'm not that good because I forgot to mention that the bell post is missing.
 After a good sleep and the grey cells recharged I find a very big problem with this movement. It hasn't got any holes to fit a dial, there are normally four, some do have three this hasn't even got a single one. I can't see any place where a punch mark might be to start drilling. My only conclusion is this movement hasn't been finished, but why would you do all this work and not drill the holes, you would drill the holes first before putting the whole thing together, it doesn't make sense. I do see some damage teeth to the barrel on the strike side.
None of those dials have any dial feet. The first dial is what I would hope to see. The arch dial doesn't have any winding holes, which makes me think it would be for a 30 hour movement as they are wound up by a chain. The last one isn't even finished, no screw holes for spandrels.
I've got to put my thinking cap on and see what I can come up with.
For some reason my new post has ended up here.
Edited by oldhippy
Weird... like you say it doesn't make sense. Is it possible that the dial would be fixed to a back plate attached to the case rather than the movement? The brass dial is only 10in square so does not fit this movement anyway.  Like you suggested, I think I need to find a 12in dial.
I know what you mean but in all the years that I have been into horology I have never seen such a thing and never seen it in any books. I could understand an amateur trying to do such a thing but this movement is good quality plus it has five pillars not the bog standard four. It has all the signs of a quality long case movement.
If that dial is a 10 inch one then that is very early.
Here is my conclusion of this movement. It never had a dial and was never finished and somehow got left. The clockmaker didn't make the dials for these clocks it would have been what we call today farmed out. A person would like a clock made so one would make to what the customer wanted the same with the dial and the makers name of the clock movement would be added to the dial not the dial maker, this one never got that far, but I still don't know why the holes weren't made before assembly, there's no marks to show where the holes are to go so it never even made it that far. Could it be just a movement for show if so that would be an answer for the fifth pillar, add weights and pendulum fix it up somehow on a bracket to a wall and a customer could see it going knowing what type of movement they will be buying,  we will never know.
I would like to read others comments on this movement as we all have different views. It's a most interesting topic and a valuable one to this ever increasing friendly forum.
10 minutes ago, buzz12 said:
That is a plausible explanation, OH.  Since I can't think of an alternative reason I will run with that for now.  Like you say, it would be good to hear if anyone has any comments or ideas. It is most unusual.
How did you get hold of the movement and all the other parts?
Like you, my late father was a clock-maker/watch repairer.  I now have, well basically the contents of his workshop.  All manner of bits, parts, tools, unfinished projects, watches and clocks that I am enjoying learning about. Sadly, although I always admired his clocks and skills, I had no interest in this fascinating topic until his passing and now or course I am kicking myself for not sharing his passion and knowledge.  As you can imagine with 25 years experience his clock skills were vast but his organization could maybe have been a little better.  I am quite sure he would have known exactly what he had, where it was and what went with what, but I am just left guessing.  Hence the dilemma I have with this movement.
Was this movement intended for use in a Grandmother clock he made that was half finished? Or, maybe it was for the relic of a long-case clock found out in the garage that had been there for years?  Or, maybe it came from that relic of a long-case?  Of course I will never know.
The position I find myself in is very frustrating but I am enjoying the learning process and thankful for all the invaluable help the forum offers.  Although I have learnt enough to resurrect a few watches I can clearly see now that things are not always what they appear, so it might take me a while longer to conquer a clock.
How nice to have all those memories of your father along with the things he had that was to do with his work. You must have already realized that watch/clockmakers or repairers never throw anything away. The amount of stuff I had It was incredible that I managed to find places to put it all. When I decided that I'd had enough I had to sort out the good from the bad, I had a skip to get rid of the real junk while the rest went to auction.
1 hour ago, clockboy said:
I agree with oldhippy it is a real strange one. I just wonder if it was a clock that was made by an apprentice clockmaker/watchmaker but never finished.
The reason I didn't go for an apprentice piece is there are no depthing tool marks on the plates for marking out the exact position of the train wheels, I would expect to see some kind of marks, in fact no marks at all.
It's still a good idea.
    • Hi. Use a PVA based glue, gorilla glue it dries transparent then do as advised by Old Hippy, smoothe down using very fine  0000 wire wool and either French polish or beeswax for a finish.
    • Hello and welcome to the forum.    Enjoy
    • The problem with oil in particular 9010 is it likes to spread. This is why you're supposed to use epilam anywhere it's used to keep the oil in place. Then you want to splurge on money you could buy 941 it's actually an oil that existed before 9415. Then the problem with the grease yes it stays in place but if you have too much you lose amplitude. Then if you get really obsessed with this he would follow Omega's recommendation for escapement lubrication. One of the problems with internal documents of the watch companies is typically are never going to see Them.But a few of them out in the wild for instance at this link Below I searched for the keyword of working. In particular working instructions of the Omega watch company for which there is way more than This but this is all they have. So you want to download number 40 as were going to talk about that and also download Number 81. Plus anything else that looks interesting https://www.cousinsuk.com/document/search?SearchString=Working Then number 40 covers lubrication of the watch. Most interesting is lubrication of the lever escapement under three different conditions with Lubrifar Which you probably no longer have has been washed off without which is what you have and then a course with epilam. Notice how they go supers super minimalistic with the 9415 because if it's too heavy you lose amplitude. Then if you lose amplitude the group will be disappointed with you and the end of the world will come.
    • You would always get an answer John, you dont need to be dramatic or humerous to get one, but it was appreciated anyway 🙂 Kind of, for those of us that wish to stay in touch and continue to learn from each other in case the forum ever dissappears then yes i suppose so . I  hope that you would also count yourself in , what we learn from you is invaluable,  how you benefit from that exactly I'm not sure, being able to teach ? I did say is it ok to ask mark for some input John and suggested that he might read the thread that explains how some of us feel. I dont see how its really discussing forum policy, but in all honesty i wish i had never even bothered now.
    • While you might have seen it as a humorous/Dramatic remark was done very deliberately so I could get an answer. Let me quote myself? The simplistic of this entire discussion is the group would like the last forever.   If you go to the top of the discussion group you'll find something to click on that says staff. Then you click on Mark's name and you find out interesting things? For instance he was last here on Saturday so yes he is here. If there is a crisis or a problem he is going to be here. You will also find a list of his activity although that's only the public activity. There's a lot of work that goes into running message boards and he probably does a lot of stuff in the background that we don't see to keep it going. Unfortunately message boards do not run themselves. Then regarding this did you notice you can message Mark and ask him. Then if somebody, we could elect somebody from this discussion such as @Neverenoughwatches To reach out I would really keep the message super simple like? You could refer him to this discussion but I would really keep it simple Like for instance the group enjoys his message board and what could we do to keep it going Forever? Then regarding all of the other suggestions comments helpful remarks or ideas? When was the last time any of you bothered to read the message board rules? This is covered which is one of the reasons I did the dramatic things I did to provoke a response of the basics as opposed to starting to suggest or seemingly suggesting all sorts of ideas which are covered by one of the rules found in the section on rules. In other words I'm going to quote something from the rules of the message board.
