Thanks, the one I currently have has a clamp, but looking at some of these posts it looks under powered. I was looking for something with adjustable brightness that at full power would pull aircraft off course 🤣
I was looking at this (link HERE):
But it seems expensive at £75.95 and I don't know if the performance is worth this cost - are there more 'bang for the buck' options out there?
I bought the L60414 from them a couple of years ago and I've been very happy with it. The one you've selected has a larger head and more LEDs, so quite possibly worth the extra.
Very informative thread! After reading through, I ordered a lamp from Amazon. Under $49 US (£39) tax shipping and delivered in 6 hours, yep! This one has 5 intensity levels and 5 color settings from 3200 to 6500. I use a binocular microscope and have the gooseneck lamp in case I need directional light. Don't mind the clutter of watches, those are usually moved off the bench when working on a watch. This really lights up the area nicely. The ring of leds on the binoculars is fairly cool when compared to the new lamp. I like it because once set it returns back to the setting when turned off and back on again.566958909_20230528_2023432.thumb.jpg.6c0677c1561d544d660b040725c90bd6.jpg1116591457_20230528_2156423.thumb.jpg.dd2bcffdb7071d01f3ce45522d310622.jpg
Could you share the like from Amazon where you bought this? Thnx
6 hours ago, Waggy said:
That looks like it. I will try to post the Amazon one.
6 hours ago, oldhippy said:
What a nice light and it hardly takes up any room and its not expensive at all.
Yes, and it doesn't give off much if any heat. Slight bit to the touch but not anything noticeable after a few inches away. There are 2 light bars that move independently up to 90 to the front/side. The light bar attaches to a bendable post, so can be manipulated a bit for height as well.
"Ksunun Double Head LED Desk Lamp, Architect Desk Lamps for Home Office, 24W Brightest Workbench Office Lighting-5 Color Modes and 5 Dimmable Eye Protection Modern Desk Lamp for Monitor Studio Reading"
Not sure how to copy the link without private info, but this is the exact product listing description.
    • Depends what sizes of watches you mostly service . If you were to say pocket watches then you might benefit by wholly replacing the 9010 for 9020. As a rough guide hp500 is twice the viscosity of 9020 which is twice the viscosity of 9010 at 20°c.  So hp500 would give you a more mid-range oil between thin 9010 and HP1300, but as it happens hp750 is more mid- range than hp500, but is that more or less useful when oiling a train of wheels. After the barrel arbor the jump down in pivot size is around half, then after the centre wheel maybe more than half until the escapement. And pivot size isn't especially a deciding factor, as the torque and speed of a pivot would be more relevant when thinking about which oil to choose. So 750 might only be useful on a centre wheel and nothing else, and 500 might be better than 1300 for oiling the centre wheel but still comprises the rest of the train, where 9020 would be ok for the train but too thin for the centre wheel, leaving only 1300 for the oiling of it. You see the problem we're having here. What can be ok for one thing is less ok for another in a different way, damping down power compared to oil spread.  Maybe mixing a drop from two opposite range viscosity synthetic oils will give you some approximate thickness oil in-between . You want a short answer now,  I tnink I'd go with the 9020. Now be prepared for a whole host of different answers.
    • So, working on watches and your karma at the same time: win-win situation!
    • @SteveF ,  Go on to Dr ranfft website,  Enter keywords Omega 26.5T3  ranfft .  There Dr ranfft  has listed all related calibers to this family, all which beat the same frequency,  any balance complete of this family fit your watch. This would only expenad your choice of balance complete.  Recolleting your hairspring is easy, but matching it with a balance of the family is challanging. Regs
    • Yes, it looks much better, but at this point the main thing is to make the spring in one plain. so picture from side will show this better. Now it is seen that #1 bending is needed, which is normal.
