How do I adjust this hairspring.
The guide pin prevents accidental unlocking of the escapement. If the pin is bent or out of line the watch will intermittently stop. One more thing about the pallets don't oil the pivots unless you have the correct oil to do so as this will cause drag and the watch will not keep good time.
If all this is satisfactory we now go on to the balance. If you still have the old one I would like to see it in good clear detail the same with the replacement. You can first check the balance pivot holes and end stones I believe at one point you said you took them apart so are you sure you have put them back properly and not mixed them up, make sure all are ok and secured and screwed in tight, don't have one side higher than the other make sure they are both level and not loose.
Let me know how that goes.
szbalogh has posted a good link of Marks, unfortunately it doesn't cover fault finding in the escapement.
Yeah, I've watched all of Mark's videos, very good and informative. I'll try to get a video of the balance stopping. I'm sure it has something to do with the pallet fork and rotor. I've checked the jewels as carefully as I can, and given my limited experience, they look fine.
I'll see what I can do regarding pictures of the balance wheels.
Bit of an update. I've tried a different pallet fork and it has definitely change something. It's running better, but clearly there is still something amiss. I've show the timegrapher readout. See what you think.IMG_0844.JPG
Swapping pallet forks is an interesting idea and for modern watches is usually acceptable. For modern watch their usually exactly the same. If you take something like American pocket watch for instance swapping a pallet fork is insane. There were variations either because things changed or machinery tolerances from the beginning of the run to the end of the run changed. Then there are adjusted for each watch. Depending upon how old your watch is there may be variations and adjustments.
Then for the timing machine if the graphical display is hard to make out then the numeric results are always suspicious. Timing machine doesn't have any magical reasoning ability to somehow filter out the garbage we see on the screen to come up with numbers. So a watch that's running very poorly visually and graphically with very low amplitudes will sometimes show up as a very high amplitude If the machine is reading the wrong part of the waveform. This is where having exotically expensive Swiss timing machines with the oscilloscope feature or timing machines software that also has the oscilloscope feature is nice to see if we can figure out what's really going on.
So if I pretend that everything is running fine, or basically I disregard my first two paragraphs. Then your watches out of beat might be nice to make that better and did you remember to lubricate the escapement? So you're almost getting a line on one side of the escapement you're not on the other that can be a variety of reasons I can pick up some really obscure reasons if you want but it's probably something simple.
Biggest problem were having or specifically I'm having for diagnostics is it be nice to hold the watch in my hand. The number one skill in watch repair is to learn to visually look at the watch in figure out what's wrong. The timing machine will point you in directions and show you things that you cannot see with your eyes but you still visually have to Be able to look at the watch in figure out what's going on. So we basically cannot 100% diagnose your watch with the timing machine print out it be nice to have a photograph of the actual watch and that's a problem of getting a decent photograph of whatever it is we perceive the problem is.
I don't think the watch is that old, '70s maybe. I was having problems with the balance stopping in one position i.e. With the balance above the pallet fork, so I thought I'd try another fork from a spare movement, to see if anything changed. I does run now, in all positions, but it still seems to be catching somewhere, as the display shows, I think.
I can't even see where the problem is, let alone take a picture. I was hoping to gather a few opinions, in the hope that something may provide a small breakthrough.
I don't have anywhere near enough experience to diagnose in the way you describe, but thanks for the input anyway.
Please ignore the picture of the balance wheel, it was just for an example of the spring collet that I was hoping to adjust to get the beat a little better (my original question)
Edited by ftwizard
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  This might be helpful for you.  704789946_TZIllustratedGlossary(2).pdf
    • I take it that you're comment re the Unicorn is 'tongue-in-cheek'? Would any of the watches that are on the link I posted be likely to be radium watches? What period was that prevalent in and when did the practice stop?
    • As much as I hate Facebook, can a forum-like place be set up on there? Free and the ownership can be taken over by the next person whenever.
    • I existed before the term mechatronics engineer existed. I had to combine electricity, electronics, pneumatics, hydraulics and computing just to keep my own equipment working. I have never sub contracted any of my own repairs to the suppliers because I know I could do a better job. For a long time, dental suppliers in my country would bring their dead equipment to me that their own engineers cannot handle. I have accidentally embarrassed a couple of hospital heads of engineering by demonstrating their inadequacy.  I think mechatronics is the most under-appreciated, under valued of all the engineering sciences. I had a part-time dental assistant about 25 years ago, who was studying mechatronics in the polytechnic. She was absolutely clueless about the job prospects for a mechatronics engineer. I asked her about her aspirations and she replied that she really wanted to work in the games industry.  In our dental profession, equipment have evolved from simple mechanical to electro-mechanical to logic-driven electro-mechanical and currently to computer driven machines.  The medical equipment suppliers who employ mechanical engineers and/or mechanical engineers cannot cope with the repairs of the newer equipment. And many times end up changing whole modules and whole machines just because they cannot repair them. But I think HR is afraid to employ a mechatronics engineer just because they don't know what a mechatronics engineer does. Mechatronics is much more fun. It combines almost all of the engineering sciences and produces an all-rounded engineer. But until HR changes their mindset, not all door will be open.
    • Welcome Tarheel, there is a lot of help on this forum...
