Hi,
  One problem i'm constantly facing is once the movement is running and I've got the dial and hands back on, I'm always struggling to remove the specs of dust from the underside of the crystal.  New crystals seems worse - as they appear to have a static charge.
What are the tricks to ensure that the underside is clean before casing the movement?
Rgrds
  Bev
Normally a blower is sufficient. Use a black background to inspect, and turn the case  in all positions under natural light. For obstinate dust, try anti-static microfiber cloth. Store the case under a jar while while working on the movement.
If it makes you feel any better it's a constant battle on any kind of watch, I can't tell you how many times I've had to fit a new glass or work dial side on a watch, inspected the glass/dial with the watch on a casing cushion, under a lamp, with an eye glass, going back and forth a dozen times being ultra thorough, and then I'll finally put the winder in and the case back on, inspect again and some debris just came out of thin air and I have to start again.
I'm not aware of anyway of making it easy, you just need a decent cloth, an airblower, a good eye and an absolute abundance of patience.
A black background is a good idea though.
Edited by Ishima
I recently had real problems trying to get the dust from the back of an Omega glass.  After polishing the acrylic the blower just wouldn't shift it.
I use clean Rodico, but even that can leave a mark.
I bought one of these 'Camera monitor lens cleaners' from ebay - it's like a solid blob of silicone, and picks of the bits of dust. Cheap, and works well
yes,  camera lens cleaning techniques  WORK FOR ME.   there is l little brush with a air puffer attached,  i use it first.  next - if   nessesary,  use the "lens cleaner  cloth  and  paper".    this is  why  watch makers like a dust free shop.   a swiss trained watch maker once told me " stay away from the inside of that  crystol !".     vinn
a while back, i got a very nice seiko watch from fleabay because the inside of the crystal was a mess. in the pictures, the dial looked awful and even questionable. i had a feeling and pulled the trigger. it turned out to be one of the cleanest watches i've got. the auction listed it as a black dial, but it turned out to be dark blue. and it was sold by the original owner! it turns out that the crystal had a film on the inside that obscured the dial. it's a beauty. that's a lesson in what a dirty crystal will do.
o.k...here's what i do. before i install a crystal, i clean it with soapy water, rinse thoroughly and blow dry. the water takes away the static charge and blow drying it assures that i'm not touching or wiping it to clean it.
  • Similar Content
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
