Bergeon 5500 tap size?
Tiktok
Just bought a Chinese version of the bergeon 5500 press, everything is good with it apart from one of the lower supports with the male thread on is not threaded right down to the shoulder so the dies won't sit on properly.
I am very surprised at how good quality the rest of it is for the price.
Does anyone know the thread size of the dies so I can order a tap and die to sort it out, the bergeon dies do fit because I have tried them. Will a normal steel tap and die be ok for aluminium?
thanks in advance
Have a sternkreuz press. But the dies from the bergeon press should fit this as it says in the manual. Mine is a ordinary M6 Tap . Maybe you could do a little cut or groove next to the stop?
Edited by rogart63
Take the removed post to any car or motorbike repair shop and they will finish up threading for next to nothing.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
