Seiko for travel
jdm
I'm packing for a month trip in Asia and I'm thinking to carry my NH36 upgraded midsize diver for the days at the beach
And this larger SARX015 for the nights around
I could take others that also very nice, but two are enough and these are still new to me.. what you guys think?
Edited by jdm
3 minutes ago, steve855 said:
How about something vintage?
Yeah, good question...I can give you my mother-in-law to take with you in the trip...you can keep her! :D
Sorry but I couldn't resist!!
you couldn't have picked a better watch for the beach. just hope there's no sand between your wrist and the bracelet. that's as bad as having sand between your.....oh forget it.
love the pinstripes on that SAR. nice pick for around town.
Bad news... the crown thread on the diver was on its last leg and quit on me yesterday. Which is a kind of a bummer because for the midsize two-part crowns are difficult to get, or perhaps is the pendant tube that is gone. I guess the watch was scared of my swimming? Now I have no water watch - oh, the shame.
Edited by jdm
that deserves a closer look. my guess is the crown is kissed. if it IS the crown tube.....ho boy! that'll leave a mark. this would be your opportunity to yank it out and go for a Rolex triplock tube.
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
    • I overhauled a ladies Rolex and noticed erratic performance so I stripped in down again and did fault finding. This is what I saw. The lower jewel (the one in the plate) is cracked and the hole is too big. Before discovering this, I stripped down and re-cleaned the main-plate (and parts) by hand with a fine natural fiber brush. I somehow missed the fault the first time and cannot understand how it was still running. Perhaps re-cleaning it dislodged some pieces of the jewel widening the hole? I don't know. Now I need to replace the jewel but don't have a Seitz tool. The Rolex part is 2130-0913 and the top and bottom are the same. The part comes complete in brass setting with KIF elastor spring and cap jewel. Note: I have never replaced a jewel. I do have a good vintage stacking set that I've used quite a bit.  Can I replace using a stacking set? Any suggestions would be greatly appreciated.
