Another newbie
Sowulo
Are you sure it is not a pivot bent or other component? I don't think dropping the watch would have caused the pins to move...just an opinion. Before you touch those, check everything else...and I mean, EVERYTHING!
Cheers,
Bob
PS. Check the pallet fork's pivots first...and hairspring/balance wheel next...including the impulse jewel.
I dont think either that dropping the watch could have caused pivots to move. But they have to be vertical. You can see it on this video at 17th minute
Pallet fork looks fine to me (I might be wrong due to lack of experience). I have to check balance again
Yes, but that wasn't the original problem. Fix one first and then check the rest.
Right now you need the watch running, after that you'll check for making it running properly. But first things first....don't change many things at a time. Change one and check, if it doesn't work, put back and change another and check...and so on. Otherwise, how would you know what is wrong and/or gain experience? Be patient, methodical and take your time...if you don't fix it today, you'll fix it tomorrow...or the next day. Once you have "the know" the other watches will be fixed faster and better.
One side of shock jewel spring was undone. Do you think that might be the case?
Also what would be the cleaning procedure? I'm thinking about ultrasound cleaner as I can't realy afford propper cleaning machine. What kind of cleaning solutions do I need? How many rinses? Same solution for rinsing? TIA
Anything with shellac should be AWAY from alcohol...NO ALCOHOL ON SHELLAC: i.e. pallet fork and hairspring assembly. Fro those use naphtha/Ronsonol/LighterFluid.
For the rest you can use the ultrasonic with the appropriate (non flammable) fluids/chemicals and/or clean everything in Ronsonol by hand.
My other hobby is fountain pens so I know alcohol dissolves shellac. What is appropriate fluid? I need names :). There so many of them so don't even know where to start. Do I need more than one? Are they based on ammonia? It must be hell of a stinky procedure...
On 5/11/2016 at 11:31 PM, Sowulo said:
I've found difficult to determine where the end of the tweezers are while looking through an eyepiece. Couple of times I poked in to movement.
You can try a binocular visor.
    • If you tend to be a little heavy handed then heres something that might help you to prevent cap jewel loses if you have some spare tweezers. File a round into each of the tips so you can grip a capstone or chaton while oiling or moving them around. Instead of filing along the length, angle file the tips first then file the rounds perpendicular to the angle. This way the tweezers wont get in the way of the oiler. Choose an angle that suits your natural hand grip position. The tweezers can now grip round parts on four sides Instead of two that often flip that part away.
    • I had noticed that video before.  He has a separate video for the reassembly. When he started the reassembly with using peg wood to oil a jewel I have to admit that I didn't watch much further. He also advocated not lubricating the center wheel arbor because the cannon pinion is friction fit. There is also a blog post (Adventures in Watchmaking, I think) that has a bit of info but not much at all with the oiling.
    • In view of the modern lubricants available, would you lubricate a clock movement differently today?
    • Yep thats the way it goes. The trick is to lead it into a false sense of security. Go through all the motions of ordering another one but dont actually click that final buy it now button, then stand up say " oh well at least I have another one on the way" .  It will pop its head out and shout " SUCKER ! " . They've done studies you know 60% of the time it works everytime.
    • Hi. I used to live in Tadcaster nor York , there for 40 yrs  moved Aberdeenshire as the place was falling apart.  If you need anything just ask the members on here are very good and patient.
