Roger the Dodger signing in!
Hi all....Roger the Dodger here!....been a long time member of both The Watch Forum (RLT) and TZ-UK.....but only found this site through the recommendation of a new member on RLT... which is a blessing really, as I want to get more involved in the servicing and repair of my own watches. Having spent hours watching Youtube vids, and having been donated several old movements to practice on by several very kind members on RLT,, I'm sure this site is going to be a goldmine of information. Most of my projects in the past have mainly been cosmetic....I've just finished the refurb of a Seiko 6139-6002 Pepsi/Pogue which included refinishing the case, new dial (aftermarket), NOS hands, new gaskets, new bracelet, and this was detailed in the 'Tinkerers Corner' of The Watch Forum. And several years ago I rebuilt a Grandfather clock which was also detailed over there. Very pleased  to see one of the Mods, Will Fly, is also a longstanding member of RLT.
I think I'm going to enjoy it here!
On 4/15/2016 at 9:54 AM, oldhippy said:
Hello and welcome. Clocks are more my thing I used to restore them so I'm most interested on your rebuilding of a (grandfather clock) Longcase.
Hi, Old Hippy...I'm going to post a link to the watch forum which should take you straight to the Grandfather Clock project if you're interested. I don't think you have to be a member to be able to see this.
http://www.thewatchforum.co.uk/index.php?/topic/58371-grandfather-clock-project/
Edit: The link seems to work, and I'm not signed in.
Your Longcase clock dates from around 1800 and it has a 5 pillar movement which takes it out of the bog standard class. I have gone through the article on the other place and I particularly like the way you did the invisible bushing it was very professional, however it is not good to add marks, The way you repaired the rack tail was extremely well done, it can be fiddly as you have to get the angle correct in order to get the strike count right.  Even though you fixed the calendar your fixing is incorrect, that is not how the original would have looked.
You have done a very fine job. Congratulations.:woohoo-jumping-smiley-emoticon:
    • My $12 blue one seems to work well enough for movements out of case. However for  tools with greater mass, such as my small and large anvils which are highly magnetized the blue unit is useless.   For whatever reason, my high current K&D donut unit just doesn’t seem to work, regardless of my attempts to use it as instructed in this thread (magnetizes stuff fine so I know it is energized).
    • PUW1563 is the day/date version of the 1561 (date only). I have just measured a 1561 using the old "blob of paint on the rim" technique to determine the actual amplitude by observation, and then putting it on my TG and adjusting the TG lift angle until the displayed amplitude matches the observed amplitude. I get 48°. Not a million miles away but it will have overstated the amplitude by about 20° with the TG set to 52° (I tried that as well for completeness). So with a more appropriate lift angle set on your TG you would have got an amplitude reading of about 240°.
    • Ok maybe that's the case - I was following this recommendation from: https://watchrepairtutorials.com/ultrasonic-watch-cleaner-how-to-get-great-results/ Here it is described to do the wash at 137 deg-F, which is 58 deg-C and he tested Elma Red with the described cleaning routine (10min wash, 5min rinse distilled water, 2min rinse 99% IPA).
    • My dad has a Citizen Pro master Wingman with a C720 movement in it. He took it to Timpsons for a battery replacement and the guy in the shop said he can't guarantee it will still be waterproof. Anyway it turns out it's not waterproof and now it's full of water. Would anyone know where I could find a technical sheet for this movement? I've tried looking online a bit today but can't find anything!   Thanks in advance
    • You would at least need to poise through those positions before regulating.
