Your favourite music thread.
I'm still on 4.9.5
Didn't upgrade as so many bad reviews every time an update came out.
Worked perfectly until the forum update.
IPBoard 3 will lose all support, including security patches by next year. I had to upgrade to IPBoard 4.
And this involved updating the Tapatalk plugin to the latest version.
There's no getting away from it - at some point you will need to upgrade your Tapatalk client.
In terms of bad reviews - my Tapatalk client is the latest update from the iOS App Store and I'm having no more problems than before. I have always found Tapatalk to be buggy and glitchy from time to time, but for the most part, fairly stable.
Thanks Mark.
I have always resisted uodating apps if they ain't broken. Also, having read people complaining about intrusive ads makes me even more hesitant.
50 minutes ago, ro63rto said:
Thanks Mark.
I see where you are coming from, which is why I resisted updating IP Board to v4 for so long. And my Mac is still running Mavericks because I don't want things to break should I upgrade, and Yosemite and El Capitan are free lol.
The ads in the Tapatalk client are a slight annoyance, I am considering paying the 79p myself to have them removed from my app.
"Hector the Hero" - on solo tenor guitar
I've been working on a lovely lament by the Victorian Scottish composer, James Scott-Skinner to commemorate the death of a  legendary Scottish soldier, Major General Sir Hector Archibald MacDonald, KCB, DSO (1853-1903), known to everyone as Fighting Mac. MacDonald, the son of a crofter, rose rapidly from the ranks to become a Major General, fighting in campaigns in the Middle and Far East. Jealousy of the fame and popularity of a down-to-earth, lowly-born soldier in the upper class ranks of the army led to rumours of homosexual behaviour in Ceylon - never really clarified. MacDonald was in Paris in 1903, en route back to Ceylon, and shot himself. A tragic end for a gallant man, demonstrating the attitudes of the establishment of the time.
The MS of the score is labelled "coronach" - a keening or improvised singing at a death. I've chosen to treat this piece a bit in the style of a pipe lament with no backing chords - just the melody played more or less in slow march time - twice through. In the (written) key of A on the tenor guitar (G voicing, capo'ed on the 2nd fret to get the open strings). I've added some grace notes here and there - and tolled the bell for Hector at the end of the piece.
Hector the Hero
  • 7 months later...
I like to listen to a variety of music and I've really enjoyed all (or most) of the selections here... I'm going to try to add to the collection with one that I've enjoyed lately.  It's one that is both haunting and uplifting, if you can imagine that combination.  It's from David Lanz and it's called "The Green Man"  Hope you enjoy it...
Hector the Hero
Really nice, melancholy little piece.  Thanks for sharing...
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile, and not less mobile which is the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
    • Would it be correct to say that the stronger the mainspring, the thicker the oil should be? So for a fusee mainspring, should a thick grease be used?
    • I started on pocket watches as they are easier to work on than wristwatches. Many had gold cases, which is why there are so many movements for sale. I was always on the look out for cases, for as Nickelsilver says,  a 16s movement will fit any 16s case* (with tweaks to the stem). I also started hand winding mainsprings, before I had winders. It can be done without damage, but it's quite hard on the fingers.  But you can make homemade winders, see here      * some movements, eg "railroad grade", have a setting lever on the edge of the  dial at about the 1 -2 o'clock, so need a special case.
