Cheap Pegwood
A while ago in another posting I mentioned that I was getting some "Cuticle Sticks" as used by manicurists etc.
My research had indicated that they are made from orange wood ie the same as our pegwood !
I have received them from the bay and total cost for a pack of 100 was £1.99 (with free P&P as well).  They are 4½ inches or about 115 mm long, chamfered at one end and pointed at the other and seem to fit the bill.  Just the right length for my hand.
Just thought I would share - if you are thinking about getting some make sure orange wood is mentioned in the description.
Cheers,
Vic
  • Like 6
A trace for "100 Pcs nail art orange wood sticks" from uk suppliers may be fruitful ramrod or pm me. I checked my skewers Folkvisor but mine are bamboo so I am unsure if they will have the same properties as orange wood. It's all a bit of fun really, last time I bought 4 mm peg wood from a "proper" supplier it cost me more than 3 times what I just paid and there was a postage charge.
Next I am going out into the nature reserve near me to check out the Elder trees so I can take the pith
Cheers,
Vic
Can confirm that the stuff I got has turned out to be excellent, sharp points on all 100 and no apparent substandard wood. Perhaps it is because of the original intended use in manicuring the quality was kept high.
Cheers,
Vic
    • Hello WRT members I started a project 4years ago printing straps for seiko model 5M42-0E69. This because the strap wasn’t produced anymore and i needed a strap for my father’s watch that come to my possession. I found someone who was willing to make a computer drawing and than he started printing and worked out well. To build up the metal caps you need to have some patience but it worked.  He fiets printed a prototype in red.
    • Hello a nd welcome ro the forum.      Enjoy.
    • I went with GBP as you guys started it off and $4.04 adjusted for inflation.
    • Great help for me - thank you all. If the hairspring has been shortened, it must have have even tighter coils than it does now and they all look utterly concentric but nevertheless I'm not leaning further towards that explanation. For me, vibrating a new hairspring would be far from easy - I wouldn't know where to start.And if a new contrate wheel has been cut and mounted, it's been done very skilfully, leaving no obvious telltale signs. Cutting and crossing out contrate wheels takes skill, too, so a bit of a last resort. and why would the he have cut 70 teeth if the existing one had 75. The platform certainly looks original to the clock but I cannot rule out the possibility that it has been taken from a similar period one (with a different tooth count). It was produced by Soldano (who supplied Dent) and the movement is by Hollingue Freres (who worked for Drocourt) so it's a nice small one (not a miniature) but I have to say that it does look like it has been worked on by someone with a hammer and centre punch instead of a bushing tool. The history isn't know - the current owner has never seen it working. I completely dismantled it again at the weekend to make the tooth count but when I've figured it out, I'll take some photos. But for now, I think I've reached the end of the line.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  You might find this helpful. 704789946_TZIllustratedGlossary(2).pdf
