New Member
PeWe
Hello all, I'm from Germany and I love it to work on watches and bring them back to live. As I'm always chasing for more watch repair related information, I found this forum by accident. I'm really suprised and happy about the wide range of information here. It's very inspiring!
Welcome to the forum PeWe, you should enjoy yourself here. Many thanks for the kind words about the forum, it is the great mix of friendly and knowledgeable members that make so good.
I would also like to extend a warm welcome to Klode.
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
