Louis Erard To Be Repaired
hokavan
Not much to go on here. It's a bit like the "what was the problem" thread without clues.
What is the history? Has it ever worked?
If "hand winding is good", does that mean you can wind it fully until it stops winding?
Where is the missing screw from the barrel bridge? Is it jammed in the mechanism somewhere?
Do the hands turn freely?
Beyond that I would start taking it apart...
S
Just break it into sections as we normally do to diagnose these types of issues.  I would start by taking the balance wheel out then taking a toothpick to the pallet fork to see if it "jumps"...if it does, look at the hairspring to ensure that none of the coils are sticking together and that it is true.  Having said all that, I have an inkling this one is simply in dire need of a service;)  Good luck!
Edited by jeffc83
    • My mentor has been using one of the Chinese clones for several years. Seems to work very well. Just put the object you wish to demagnetize in the centre of the cross and press the button. One word of caution though, the quality and QC of Chinese clones can vary a lot. You'll never know whether you got a gem or a lemon.
    • You could also use a very fine artist's brush to brush between the coils.  If you get a size 00 or even 000 that should be small enough for convenience, and with bristles so fine that they are incapable of damaging the hairspring.  Get a good one though, like Windsor-Newton or similar.  I have never had a Windsor-Newton brush shed on my art or other work.  You want a soft brush that will not shed.
    • Sounds interesting but how do you push the button if you’re holding both ends? the large current draw overheats after 3-5 seconds and the thermister triggers. A great tool for magnetizing things but I’ve not be able to ever demag anything with it because the emf is so strong it pulls the item off center (down or up).   I paid $89 bucks for it from  CAS-KER, if someone on the board wants it I’d gladly sell it for $25 plus shipping (probably US only otherwise postal costs are prohibitive). Just sent me a note offline.
    • Hi. First thing to do is measure your oil movement as the vx32E and the 43 look very similar but one is a couple of mill smaller the vx32E.  Also the canon pinion heights differ attached tech sheets for 7N22. And  VX43, check details on the sheets. 7N22A_29A_33A_42A_43A.pdf VX43.pdf Hattori VX32E - Specification.pdf Hattori VX32E - Disassemble.pdf
