5 minutes ago, nickelsilver said:
I am American, expated in Schweiz for over 20 years! Yes, tenacious mank is a real problem, actually almost killed us as watchmaking students with a fresh batch of new old stock movements. Through the top of the line machine, garbage. We pegged and pithed for like 2 days to get that mank off and hit 270 amplitude. Would love to know what original oil was used.
Haha. And all we did at joinery school was try to set each other on fire with lit wood shavings and have nail gun shoots outs. Oh fun days, then I had to grow up and become sensible.  Why is my wife laughing and shaking her head ?
I think I'm ready to abandon the use of lighter fluid to clean my watch parts and use a dedicated ultrasonic solution from either Zenith or L&R.  Question is: if I use a mason jar with the parts baskets in it, do I leave the jar uncovered while ultrasonic-ing, covered with lid but not secured (to allow it to vent), or completely shut with lid?
And how much can I reuse the main cleaner before having to dispose?  How much can I use a rinse before having to dispose?
Does anyone have recommendations for which one to use?  I prefer non-ammoniated, both for the purposes of smell and the possibility of the ammonia attacking the metal.  I know L&R 566 is ammonia free.  Don't know about anything by Zenith.
Edited by GregG
I use both naptha and ammoniated elma. It makes the parts very shiny although i think is that necessary? It does stink i use an open plastic tub but have an extractor. I noticed pressure build up inside sealed glass  jars when i used them, so maybe just a tiny hole in the lid to vent the pressure. I think you will know when to change the cleaner by looking at its state. I do filter the cleaner but monitor its cleaning efficiency. I also filter quite often just to keep the cleaning up to scratch. I cant say I've noticed the regular filtering effects its performance until its been used for a good while.
A couple of weeks ago I picked up a set of four of these 300ml jars. The Elma basket fits inside very nicely. I fill the basket with parts, drop into the jar and put that into the ultrasonic, then fill the ultrasonic with water to a point below the rim of the jar. I don't use the lids for the jars but so far I've just been pouring my naphtha and IPA back into their containers. Part of me likes the economy of using naphtha and IPA but I might break down and buy a gallon each of the L&R cleaning and rinse solutions (to last the rest of my life). If I do that, I'll use the lids on the jars.
Edited by grsnovi
clarified "it"
You've been ultrasonic-ing pure naphtha?  What is the flash point of that?  I've read forum posts of people who have sonicated petroleum ether (32F flash point) with no problems.
Yes, in as much as I put the naphtha into the jar and the jar goes into the water bath of the u/s. I don't run the heater on the u/s. So far I haven't blown anything up (but it wouldn't surprise me if I do eventually, nothing else seems to be going right).
I have to say that I'm very likely to switch over to using the $50/gallon L&R cleaners.
I think you mean 32 C' greg otherwise the firebrigades are going to be extremely busy. I have used naptha at 50 degrees Celsius but that was by accidentally turning  the us heater on. I consider myself quite lucky. I stick to around 35 C which the us may reach on its own without the heater on. Still i wouldnt leave it alone running in the room. Check out my homemade gear post. Possibly a better alternative if you are worried. Its a rotary washer made from an old pillar drill , its actually pretty good. Very cheap to make and much quieter. I had plans for a MKII but  MKl  works so well i may not bother now.
$50 per gallon ? Which one is that gary ?
Definitely 32F (see attached picture).
2 hours ago, Paul80 said:
L&R 111 is £50 for 3.8 litres in the UK which I about a US gallon so for 50 bucks you are getting it cheap 😎
I did the math, and petroleum ether comes out to about the same price per ounce as 566 and 111. Difference is you can buy small quantities of lighter fluid XD
7 minutes ago, Neverenoughwatches said:
Thats freezing point 0 degrees Celsius isnt it ? Pretty volatile stuff then.🔥  🚒
That's only the flash temperature though, look at the auto ignition temperature, it's quite high.
Ok, but im not sure what any of that means. I even have a few friends that are firemen lol
Flash is the temperature when the fumes would briefly ignite if exposed to a  heat source.  So don't have any flames near it, obviously. All it really tells you is that it's volatile I.e has a low boiling point.
The autoignition temperature means that if it was heated to that temperature it would burst into flames.
make sure when you're purchasing this you also purchase the associated rinse that goes with it.
then in the US you can purchase it from Amazon at about $10 more but it includes free shipping. Claims if I ordered it now I can have it by Thursday. So looks like relatively fast shipping.
https://www.amazon.com/Ultrasonic-Ammoniated-Watch-Cleaning-Solution/dp/B06X9CC2RM/ref=sr_1_2?crid=2L7XCW6QIFH2W&keywords=l%26r+s+%23111+waterless+watch+cleaning+solution+ammoniated&qid=1654622753&sprefix=l%26R+111%2Caps%2C161&sr=8-2
Maybe this was already posted in the forum but I can't find any info.
Homemade cleaning solution
What do you think about the recipe? I'm from Spain and I can't get a proper cleaning solution cheap because import taxes but I can gather the ingredients very cheaply.
I have already bought tetrachloroethylene for one dip substitute.
If I’m completely honest, I’ve tried the route of tetrachloroethylene as a replacement for One Dip or B Dip. While tetrachloroethylene on its own does an ok job, it’s still not as good as B Dip at the end. Yes, I know tetrachloroethylene is a key ingredient in B Dip (they both even have the same odour), but Bergeon obviously has something else they add to spice up the mix. A 50ml bottle of B Dip goes a long way so I would get a bottle if I was you.
I do agree on the merits of a home made cleaning solution in your case (where importing commercial cleaners are a problem) especially in large quantities. I also use a locally available brew that seems very close to what your link above describes.
Edited by gbyleveldt
I've tried this before but this is recommended for clocks only.
It doesn't work as well as commercial cleaners. The brass comes out shinier but a little patchy. Dried up grease doesn't come off very well. And some steel parts will start to rust the moment it comes out of the solution. I suspect commercial cleaners contain a rust inhibitor which is not listed in the MSDS.
18 hours ago, Neverenoughwatches said:
How do you rate the 111 ? please paul
L&R #111 is a very good cleaner. It removes stubborn grease, shines up brass and doesn't smell half bad if used in a sealed jar in the ultrasonic.
The only drawback is the price. It costs $180 SGD in Singapore, which is about £100. And you need the #3 rinse which is the same price.
I try to stretch my dollar by doing a manual pre-clean when disassembling and a pre-soak in benzine before putting it in the #111. And when the solution looks a little cloudy, I put the jar in the freezer to freeze-distill some of the dissolved oils, then filter the solution to remove any particulate matter.
But #111 is way too expensive to use for clocks. 😥
  • Thanks 2
Thank you for your answers, I understand that professionally made cleaners are the option to go but for the moment I will try with the home made and in the future I will move to the pro option.
I read something about ammonia dissolving shellac, is that true? A lot of professionally made cleaners have an ammonia base so I find it odd.
Any part that had shellac I always cleaned it in Ronsonal lighter fluid.  I have said that many times on this forum. It is safe you could leave the parts in it for days and it won't come to any harm. Get yourself a small screw on lid jar as it evaporates quick. It is not a rerecorded watch cleaning agent but it works and does a fine job.
That's very similar to a mix I found in an old book and also one the local drugstore used to mix up for clockmakers around here, they called it soupe Vaudoise  (canton Vaud is a big watchmaking area). I've used a recipe from the Finnish watchmaking school for years, no problem, no rust, if anything it's a little too gentle- but I'd rather pre-clean and have a gentle cleaner than have one that etches the plates. It's probably been posted above somewhere, but here again
1L 99% isopropyl alcohol
3L distilled water
50g oxalic acid
60g oleic acid
around 80 grams of 24% ammonia
In a stainless pot, heat the alcohol and 1L water, add the oxalic acid (powder) and dissolve, add the rest of the water and oleic acid, then add ammonia slowly. It will go cloudy, then turn clear. The ammonia is reacting with the oleic acid making a soap, when it goes clear all the oleic has reacted. This keeps the solution fairly safe for brass, as the ammonia now being a soap doesn't eat the metal like some other cleaners with higher ammonia concentrations.
Rinse in hot water, with a final bath in alcohol before drying with hot air. I have never had a part rust with this, but the final alcohol rinse is important.
In that one there's no added soap, since the oleic and ammonia have made a soap. Not sure why Mike adds so much- but again, I've seen similar other solutions.
I've also posted somewhere in the past a recipe Gruen suggests when the watchmaker doesn't have access to proper solutions:
Gruen recipe:
1 ounce oleic acid
2 ounces acetone
4 ounces 22% ammonia
25 ounces distilled water
Not that different than the Finnish one. The oxalic acid in the Finnish one is a common chemical used to remove rust stains; in high concentration it will remove heavy rust as well. In this dilute concentration I wonder if it acts more as a preventative? Like I said I haven't had rust issues with it.
Some will say never use a water based cleaner as- wait for it- it will rust parts. I used Greiner GS watch concentrate as my watch cleaner for many years; this is water based, mixed 1:19 with water, and rinsed in alcohol (in a purpose made machine from Greiner in my case). Once again, no rust issues, and no issues with shellac dissolving unless I forgot the parts in the (hot) alcohol for quite a while.
It's IPA that affects certain types of Shellac - ammonia based solutions are perfectly safe hence its use in commercial solutions. We spoke about it on another thread yesterday if I recall. In any case I keep pallet forks separate from my usual cleaning regime and they get their own cleaning in Naphta (lighter fluid) then One Dip / B Dip.
Gruen recipe:
1 ounce oleic acid
2 ounces acetone
I will try this recipe for my next batch as I already have all the ingredients.
The cleaning solution I have made has among its ingredients dish soap that was originally green but now the solution has turned reddish-brown (I suppose the ammonia or acetone has attack de colorant component of the dish soap), I think this is not a problem.
If I do this Gruen recipe should I water it down when using for cleaning?
So only the pallet forks goes to naphta, can I put the rest of the balance wheel and plate in the ultrasonic cleaner (mounted in the movement) or is better to clean it also separately in naphta?
Edited by joaquin
clarification
Here's the document (it's got plenty of other interesting information in it) Gruen Watchmaking Institute Course, page 72
As written, it's to be used straight, but it does sound kind of strong. But Gruen knew what they were doing, no doubt about that.
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
