Broken Mainspring Screw
avkxyz
It is more than likely that the price of the arbor + shipping will way exceed the value of the watch.
If it is a customer's watch (ie you are repairing and charging money) the cost will make them say 'don't bother' and the watch will remain unfixed.
If it is yours then chuck it in your drawer but keep your eye open for an organ donor.
If you still want to try to get the broken piece out - try heating it, then gripping the visible end with a sharp, thin cutting tool and turning. (i have used nail-clippers to good effect as the blade portion is narrow in width but sharp. Side cutters are usually too clumsy for this application.
HTH
Anil
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
