Please Edify Me.
I know how to polish scratches out of acrylic lenses but I am a bit wary about attacking a mineral glass lens.  I ordered some cerium oxide online (now have a bag of it) and I was fortunate enough to have been given a Dremel kit for Christmas which includes a lot of felt pad tips.
I have a watch with a mineral glass lens that has a tiny nick in it...only visible if you look closely.  Problem is I KNOW it's there and I am obsessive about such things.  Please tell me if the following procedure to polish the lens is correct:
1. Wear a mask and protective eye wear.
2. Using masking tape, mask around the outer part of the lens so that the watch has a protective collar.
2. Dab a bit of the oxide on a wet cotton q-tip and smear it on the lens.
3. Use the Dremel with the felt tip for no longer than thirty seconds and then wait a bit for the glass to cool down.
4. Do step 3 and 4 again for a couple of more repeats.
5. Wipe off the remaining oxide, clear off the masking tap and wipe with a microfibre cloth.
Is that about right???
After struggling with cerium oxide slurries that fly around all over the shop when spun on a Dremel mop, I was encouraged by other members to use diamond pastes, now very cheap, oil based and faster than cerium oxide. Here is one source:
eBay # 301295006953
Isn't it difficult to get an even surface when polish with a dremel? Have polished mineral crystals by putting a 1200 emery paper on a flat surface and pressing the crystal or the whole watch against the paper instead . Then polish it with ceriumoxide.
Thanks for the advice.  I am fearful of using sand paper.  I once had a really bad experience trying to remove a deep scratch in the clear coat of my car's paint.  I had the finest grade and did all the things I was told to do but I still managed to ruin a section of the clear coat necessitating taking the car to a body repair shop and having it professionally (and expensively) resprayed.
Oh how I wish that Nissan would allow all companies to access their data on self-healing paint finishes.  Why they haven't used it on all their cars is a bit perplexing but, I suppose, to do so would mean the finishes on the cars would never age, thereby diminishing sales.  It reminds me of that great British film: "The Man in the White Suite" (1951- Alec Guinness starring)
eBay # 301295006953
i just looked up that link. i really would like to try my hand at polishing mineral crystal. i have quite a few that need help.
in using this stuff, what kind of a base would you use as a flat surface to polish a crystal? i would think that using something such as glass, it would dish out quite fast and be "nonflat" really quick. maybe?
What I have done quite successfully is grind crystals on a diamond abrasive plate. I have a sharpening block with 4 different sized diamond plates  about 200 x 75mm , I got some watches from Ramon that the crystals were opaque they were so badly scratched, I started off at 400 grit then 600 grit on the diamond then wet & dry emery paper on a sheet of glass 800, 1200, 1500 and 2000 grit grinding wet, (takes a lot of time) then used a dremel with a felt wheel and "Brasso", (a metal polishing paste got used of it in the Army polishing the brass ware ) works well on plastic crystals but don't use the dremel ot you will melt the plastic.
Max
well, i've got at least 8 or ten of them. at about 30+ bucks each, it adds up. i'd like an alternate to buying.
i remember that max posted his method on another forum, but i never got around to using that method. i was hoping that you might chime in, max.
Edited by ramrod
eBay # 301295006953
Diamond pastes are also good for polishing stainless steel watch case and bracelet to mirror finish.
Edited by steven
    • Thought I had to share this - last time I cleaned out a deep fat fryer there was less mess than this. Another pin pallet movement. Unsurprisingly dunking it in Castrol GTX didn't fix the broken mainspring which is the only issue I've found.    Any tips for the dial? Also covered in oil.  Cleaned up quite nicely
    • Hi Nev . No i didn't try this balance in the movement as it didn't run and the deformed staff broke when i removed the roller. Problem is what i think is the correct staff for this movement, the hub seat, roller and collet profiles are all too small for those parts of the assembly. The movement listed on Ranfft's site is correct my movement and the nos staffs i have match the ronda measurements. I can only assume that the wheel , roller and collet openings have all been broached to make them fit an oversized staff, both staff pivots had also been modified.
    • Yes, threw it on the demagnetizer before I cleaned it to be sure.  This picture doesn't show it well, but I can definitely see liquid where the turns meet up.
    • My newest 404 candidate, a late '60's / early '70's Waltham with a UTC 33 / Seiko 6601 17 jewel automatic movement. It needed a new crystal and I put on a strap from my Strap Graveyard. The timegrapher was a snow storm before servicing but it cleaned up nicely. I really like the funky font used for the hour markers.
    • Hi Rich, the main problem with the balance is if the roller is from this movement. Did Yoy try if the balance interacted correctly with the lever? You can use suitable (by size) balance/hairspring couple from You pile of balances, but the roller must be for this lever (original for the calibre). Not that making roller is impossible, but it is easier to have one.
