Asian 7750?
Paul78
Ive been asked if i can repair a replica watch which has a replica valjoux 7750 movement, im led to believe this is an Asian 7750. Is this the actual brand or is it just called an asian 7750 becuas its from asia? and secondly, where can i get one if i need parts?
I assumed it would be a china movement, but no luck in fnding which one if it is.
Thanks
It is just called Asian. There are different factories, none of which have a name or makes parts avaialble. Some parts could be interchangeable with the original, some are not. Apparently the people that knows the details do not seem to hang out in Internet forums.
It is cheap and if you need a two-subdials version a complete watch is even cheaper, but consider that shipping always take a minimum of three weeks.
The same is also available from Cousins UK for a little more.
This is the way it,s going to go with all ETA and other Swiss movements. Just replacing the whole movement is the only option .
When you look at the vast reduction of the labour costs its a very sensible & economical repair/fix.
I agree BUT if no parts are available there is only one option.
I think that is for the owner of original watch owner to decide, not the repairer. Fit a generic movement and basically kill watch's value, or bring it to an "official watchmaker" that has unlimited access to ETA parts.
I have been buying old, faulty ETA movements for a year or so now, mainly for the sole purpose of salvaging what I can, and stockpile the spares in compartment storage boxes.  Takes a lot of time, but its a worthy thing to do.
Agree the customer is always right
Don't you find that the parts that actually break are always the same, and you risk collecting parts that will never be needed?
Hi guys,
I went to AliExpress but only found complete watches. Do they actually sell movements? Maybe I'm missing something?
On the other hand, I've stock piled some common ETA faulty movements too. At some point I'll be making most of them runners again and if parts become difficult I already have the donors...
Cheers,
Bob
What's your definition of an 'Official Watch Maker' ?? Just because I refuse to spend thousands on overpriced tools to repair swatch group watches does that make my business (which has repaired over 2500 watches and clocks in the last 12 months ) not official??
And can I just point out, my question is regarding a replica Cartier watch, which currently has an Asia 7750, no one is going to replace ETA with chinese
If you noticed I've used double quotes to de-empathize the significance of "official". Clearly, myself as anybody else on this forum sympathize with independent watchmakers.
Unfortunately that doesn't change the fact that a business not officially recognized by the maker will have no access to ETA parts anymore, let alone hobbyists,
Edited by jdm
Yes, that is something I have noticed, however, the way I see it, even ETA parts left over, other movements parts from other faulty ETA movements help assemble a fully working movement, sometimes takes months, or years no doubt, I never throw any parts away.
The answer to your question as far as the watch manufacturers are concerned is ......... Yes.
Unfortunately this is the sad truth of the matter, and that is no reflection on how good you are. You will of course still be able to continue servicing watches, and as long as it is just CLA there will not be an issue. If parts are required, you will only be able to purchase them from suppliers like of Cousins until their stock runs out. After that it will be a case of trawl the net for what you can dredge up.
    • Just picked this up earlier today. This find just about epitomizes vintage watch collecting for me and what really keeps me going. Hit 2 antique malls today and saw a couple of pieces at the first one but just nothing that I needed. At the second one saw a Accutron 218 but it was 20 minutes behind the actual time. These "malls" have numerous booths of a variety of sellers who likely go in once or twice a week. Considering that that watch should be within a couple of seconds a month, I figured it hadn't been phased so passed on that for now knowing it would need work to run correctly and the price tag. Then I found this Excelle in a display case. I never heard of the brand, but in was an auto and had a little heft. It turned out to be 40mm lug to lug, 35.3mm case width, and 12.3 mm thick. On the spiedel once size fits most flex band. At $10.80US with tax I immediately pulled the trigger with nothing to lose. Before pictures: I spent a nice 30 minutes taking it out of the case and running that through the ultra sonic replacing the crystal and gasket and recasing, but spent five minutes first getting it running close on the timegrapher. Had a new crystal already in stock. I probably could have sanbed and polished the old one, but for $3 there is nothing like a new acrylic that makes a watch pop, in my opinion. The caseback gasket was hardened and just glad it wasn't tar. Changed that as well. Here is the after Pic on a temp black strap while I decide on a leather or steel bracelet. An added bonus was doing some research and finding out the Elgin connection and the movement is a PUW 1563T which is German I am pretty sure and probably why it doesn't say Swiss made on the dial. This movement is supposed to have a hack feature and quickset date by pushing the crown. But neither of those complications seem to be working. Not sure if the stem is cut too short because there is no gap for the crown to move. Either way at some point will need to be serviced and check the keyless works to find out what is going on with the quickset and hack of the sweep second hand.
    • On the link that I posted, one of the watches has no crown and another has a crown that is not square to the case. Does a broken crown signify that the movement may be quite corroded, hence the stem has broken, and does the bent crown simply signify that the stem is bent? Unfortunately as the seller has a bid on the items, he is now reticent to prise the casebacks off in case he damages something. The seller did reply with this email though. Hi again Michael - brief descriptions; Oris x 2, dials and hands ok and they set ok and one I just wound and it has been running for a few of minutes as I write this response. Rocar, dial ok no crown. No name dial no good and can't pull crown out to set. Roma dial and hands ok, I think it is pin pallet movement. Unicorn, good dial and hands and plexiglass ok for age. All cases and plexiglasses show wear except as mentioned. I have no idea what movements are fitted or condition so please if you do consider bidding, please do so accordingly as I don't like to disappoint my customers - regards and thanks again for your interest - Jim
    • The incomplete Vertex DD is a new project to sort out.  The Seiko gen 1, is my favourite watch to wear and is my daily.
    • To be fair it was a beautiful 'bumper'.  But, there was some loose parts in the case.  Perhaps 'pig' was a bit excessive 😄.
