Hi Im Craig from Australia and inherited the watch bug from my uncle. Everything from a 70s Delmer sunburst brown diver to a Tudor BBBBB. Love Casios and Timex.  Looking for soneone who has movement ir can repair out Red Dot Diver 70-80s. Movement is pinned/riveted and is running but very fast. Im not really in the position of repairing but its a nice piece with Timex bracelet. Thankyou
Hello and welcome to the forum enjoy.  If you open up the case back and post pictures of the movement it would be a great help. Your problem may only be a sticky balance spring or a dirty movement .
that is the second generation Red Dot which can be determined by the dash markers and chromed hands.  Original bracelets did not have the Timex logo.  The one you have is from the same era Timex Quartz.  "pinned/riveted"....those are the most misused words for vintage Timex and absolutely untrue!  This model use the M106 movement and can be a bit of a pain to get running properly.
I sounds like the beat is off and likely related to the hairspring not breathing fully. Or it is sitting at an angle and not parallel to the balance wheel.  Have you opened the back? Take a look at how the balance wheel swings.   Does it sort of wobble?
Thankyou, JerseyMo the balance wheel seems fine. Degaussed and ready for a clean up. Do you restore these? I sorta like it but dont like unoriginal bracelet of course. Thankyou for your help
Sorry, I do not take in repairs.  Short of pulling out the movement you can try to freshen up some of the pivots on the back plate.  Also add a dot of lube to the pallet pins.  Maybe move the regulator to middle and see if that has any impact.
