Blew it with a coil
I'm sure you will get help on here soon.
Kkramme we like new members to make an introduction before posting. A little about your self such as where you life and what got you interested in Horology
Thanks. I did make a self introduction— perhaps in the wrong place? 🤔😢In any I am an Australian 🇦🇺 American living in the beautiful Gold Coast, Queensland Australia. I love Grand Seiko and Seiko watches, and recently came back from the Grand Seiko Shizukuishi Studio in northern Japan where I was blown away by the design artistry and technical excellence. More later on that (including photos, if interested!)
Here are some photos of the undamaged and damaged coil.  My bad!  I find it interesting because it is an "old" Seiko Credor -- which later evolved into $20K watches!
Sometimes surface damage like this can be repaired with solder. Run pre-tinned soldering iron tip with a tiny blob of solder over the damaged area and pray that the Gods of watchmaking are on your side. 🤞
the problem with vintage watches and yes quartz watches can be vintage is availability of parts will be a problem. I have a link below where we can cross reference the coil and  I was hoping for more.
Another problem for vintage parts are everyone on the group gets used to ordering from online. Conceivably the physical material houses that still exist out there might have the part and you'd have to reach out to them and see if anyone has one. this is because they don't list every single part that they have online with the exception of cousins where everything they do is online work just doesn't exist but the other material houses can have stuff not listed.
Otherwise just set up a search on eBay and sooner or later it will possibly show up if you're lucky.
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=SEK_6020A
17 hours ago, HectorLooi said:
You don't have to use his special tester. Any good multimeter would work.
Thanks.🙏 Very helpful.
13 hours ago, watchweasol said:
Hi. Breaks like this can br fixed with conductive paint like the paint used to repair a car  rear screen heater. I have used it successfully, you don’t need much and unlike solder there is no heat
What a cool and talented and helpful group/community!   Well done -- and much appreciated!
14 minutes ago, CYCLOPS said:
Yep, i pulled that up as well when i was looking,  there is definitely parts out there if you are prepared to go out and find them.
I watched that video years ago, I'm not so sure about probing the coil like that. If you are going to touch the coil use the side of the probe or at least shape a nice round end to it.
Hi. It’s always better to replace the coil but in the event of being unable to find one it’s nice to know that repairs can be effected. I prefer the conductive paint option because of the lack of heat and the chance of causing further damage.
Would the paint increase the resistance of the coil ?
Effectively joining the wires that are painted. I imagine its important to only paint the smallest of areas to make the repair.
In think you are effectively shortening the coil by shorting out damaged tracks. In my case as long as the continuity was good and the resistance not too greatly affected it should be ok .  One was on an era  movement,
  • Thanks 2
Thanks ww, its maybe not as much of a bodge trick that i thought it was.
On 4/27/2024 at 4:11 AM, watchweasol said:
Hi New. More of a get you out of a hole than a bodge. There is no substitute for a new coil.
Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
[Myota2034] Custom simple quartz watch — PricewaterhouseCoopers
On a very very different note, here is a watch from approximately 2000 when I was a Partner with PwC, Management Consulting.
It was a simple “marketing watch” with a clever “vase of knowledge” that is subtly revealed on the dial as the second hand progresses.
Clever for a simple watch!⌚
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811uk close but no cigar 🙂 I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123 I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively 🙂 ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
    • As an alternative, clear nail Polish, the advantage is you can have a manicure at the same time.
    • I use Grammarly. It works really well and If English is not your first language, you will also receive help with formulations. There is a free version that covers most of my needs. It installs as a plug-in and works with all browsers and word processors.
