Impulse jewel on balance staff
Yes exactly scott, i managed to make it run perfectly true and then reintroduced some calculated wobble using a special formula that i created myself .🙂 -
I could only improve it, its still not perfect, the slight bit of wobble left seems to add to the agitation. -
Demagnetising of an anvil will depend of the anvil size. If it is big, then nither Elma, nor chinese clone will do the job. But the K&D from the picture will do. Have in mind that the bigger is the object, the stronger is the magnetic force that it will fill inside the field. If You can't hold the object still, then You will need demagnetiser that works on higher frequency rather than smaller one. -
Forgot to mention that only demagnetize a balance when its in the movement, otherwise the magnetic field will snatch the coils and damage them
