I've been trying to save this pocket watch which was in a bit of a state when I got it. All parts cleaned, oiled and gresed. Everyting works well with nice power at the pallet fork. When installed on its own the balance spins nicely although comes to a very slighty sticky stop but I have had much worse that still letes the movement work.. I have inspected the jewels (cap jewel for one balance pivot is missing) and all seems fine.
When installing the balance it does move the fork left to right. But it is sticky and will not run. There is friction somewhere but I have spent hours trying to find it. note the hair spring is a bit messed up. I have straightened it as best as I can and as I say when installed on its own the balance spins nicely. Only when it meets the fork does it seem to 'gum up'.
Thoughts appreciated!
Hi there,
 Check if roller  rubs on fork horns, in which case it should run OK if  the movement is flipped upside down.
Check if the guard pin rubs on roller.
Make sure balance rim doesn't rub on fork cock.
Good luck.
1. Impulse jewel is not in plase, move it down and glue it with shellak.
2. Demagnetize the whole balance and the lever. It is of significant importance when the roller and the fork both are made of steel. Here the guard pin is not separate part, it is part of the fork which can not be regulated and should be OK if all is original.
Edited by nevenbekriev
Hi if you are missing a cap jewel the balance end shake is effected and un less rectified will have an adverse effect on the movement ie. If the watch is placed in a position with the missing cap jewel the staff shoulders can rub on the setting and cause all manner of problems.
1 hour ago, HectorLooi said:
How can this be fine?
I guess just  luck.
The fork horn  might be dirty, clean with a soft  tooth brush in lighter fluid.
Edited by Nucejoe
8 hours ago, Nucejoe said:
I guess just  luck.
The op has inspected the jewels and all seems fine. Except he has a cap jewel missing. I think maybe his "fine" is somewhat different to our fine lol. For things to be more fine that cap jewel needs to be not missing.  Or am i missing something, possibly some diplomacy 🤪
  • Haha 2
Hi matey,
 As soon as the OP flips the movement upside down, all questions in regard to the effect of a missing cap stone, is answered.
There  , however,  remains the point made earlier about  pivot shoulder rubbing on the setting which depends on what side is up what down and the side that still has cap stone and pivot lenIgth.
FYI, I am 100% a meat & potato man, no diplomacy.😄
Rgds
Edited by Nucejoe
OP says that htre balance oscillates OK. It is possible that the missing cap stone is 'replaced' by piece of main spring under the stone plate. It is just a filling that i have...
Thats an interesting solution to a missing cap jewel.  I've seen that recently, discovered under a balance top plate, maybe wasn't here on our forum.  If its a filling you have Nev i think you should speak to HectorLooi,  he used to be a dentist 🤣
Edited by Neverenoughwatches
Had a Patek in with the cap jewel glued in place, missing the (Kif) hole jewel. So the staff was running on the diameter that contacts the setting in event of a shock- but it was actually running!
Have definitely seen bits of mainspring clamped down to make up for a broken or missing cap jewel too.
I have seen an army of baby cock roaches  run every which way out of a pocket watch as soon as  got the backplate opened. 🤣
Nickelsilver,  a day will come, I have success  making you laugh.
Rgds
Edited by Nucejoe
Rgds
Haha, its not a myth Joe, Nicklesilver has pressed that laughing face icon . He might have even laughed at me once ( inside ) . Its making John laugh that's my nemesis , it will happen one day even if i have to go to seattle and beat it out of him 🤣🤣🤣🤣
See, my wife is a doctor, and she is willing to hear about all my feelings... But some of them should be never shared.
About the pieces of springs - it is a common solution used by many watchmakers in the past. And the results are not bad at all, especially when this is the dial side cap stone. I use to call this side 'down' or 'bottom' side of the balance or movement. There are watches made with such plate made entirely of steel instead of jeweled plate on the dial side. A pocket watch is not expected to work in dial down position for a long time.
I can't quite make out if that's sarcasm or not Nev 😅.  And speaking of dentists i bought some of the seperating disks your were talking about a few weeks ago. 👍 brilliant idea and so much cheaper and easier to use than slotting files. Great tip.
This disks can be used to entyrely form and grind figure springs and setting lever springs of hardened steel
Ok Nev, i think maybe the dentist filling joke went right over your head 🙂
I'm not sure if I got it, what i thought is that I may be need to share my feeligs with some psychologist, but if we have not one in the group, then I can use the dentist...
A, now i see that i have typed 'filling' instead feeling. This is my bloody english...
Haha that was it Nev, we got there in the end 😅
They're brill Nev, 0.2mm diamond disks they work great with my new little milling machine. I paid less than £1 each, what is your currency ?
Could you let me know where to get them? I use slotting files, but always on the lookout for alternatives that work.
Apologies if I've taken this thread off on a tangent!
I've had the same on my bench, where the escape wheel cap was shellacked into place and it ran pretty damn well, to be honest
Edited by Jon
Theres a few different types , i went for 19mm solid disk, the diamond continues upto and around the edge of the disk. I'm guessing the grit is around 200ish , a bit rougher than i would have liked. I removed the slot from a small screw and had it cut back in by hand within a couple of minutes of fettling.
https://www.ebay.co.uk/itm/404219193851?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=qx1zhgfvseo&sssrc=4429486&ssuid=tBiLZaCfRb2&var=&widget_ver=artemis&media=COPY
Its making John laugh that's my nemesis.
Ya John is a tough one too.
33 minutes ago, nevenbekriev said:
My currency is BGN (Bulgarian Lev), which is fasten to EUR, so 1EUR = 2BGN
I am afraid we have stollen the conversation away from the OP problem...
Agree we hijacked this thread.
 I visited Bulgaria 32 years ago, good ice cream,  brought back a few little and cute levas , bought an overcoat for $11، whose price tag I know was $240 in the US. Cheap boose and Doctors visited patient for free.
Doubt if it still as inexpensive nowadays.
Not to mention that piece of mainspring as cap stone, is watch destruction.
Rgds
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
