Old HAC Clock
Michael20
Hello all, this is my first post here so I hope I don't break any rules. I have recently bought an old HAC clock on eBay, just to gain some experience rather than as a serious restoration project.  The case is a total wreck but I cleaned the movement and it is now keeping really good time. I guess I am not the first person to fall for this because now its running, I can't resist the challenge to try to get it back to its original state, my problem is finding parts. The front door / glass is missing and there is no key and pendulum. If I could find a similar clock on eBay I would at least have something to go on  but after several days searching I have drawn a blank. I'll attach a few pics in the hope that someone has one on the shelf at home (bit of a longshot I know) also it would be nice to know the approximate age if anyone has any info on that.
Thanks in advance
Michael
Hi and welcome to the forum,  glass if it’s flat can begot from any glazier, if domed that’s a challenge but can be usually sourced on eBay. The same applies to movements which also appear for sale, ihave a few old clocks in the work shop and will have a look.
the case although looking rough will respond to cleaning and a littleTLC.  With rough cases very fine wire wool and methylated spit its work well in removing old and dirty varnish.  Plenty of books on the subject  and clock repair should you require some recommendations just ask.
H A C stands for Hamburg American Clock Company.
So it is after 1900 probably around the WW1 so 1914. Looks to be a 30 hour movement going by the spring. The hands are odd the hour is in the style of what is called moon the minute is what is called Spade. All wood case and the inside is still very rough which is what you would get.  Needs a lot of T L C. With the internet you should be able to pick up a pendulum and you might be lucky with a bezel.
Thank you everyone for your responses. Regarding the pendulum, I had assumed I needed to get the correct weight pendulum bob, so it seems I have some reading to do. Thank you oldhippy, the date is nice to know. I hadn't noticed the hands were odd, again some reading required. The case needs to be completely dismantled and reglued as it isn't square and there is surplus glue oozing from every joint. I have seen a few pendulums that would fit but wanted to find an original if possible. The bezel has defeated me so far but if I can find a picture of a complete clock it would improve my chances. I'll post the pictures as requested by watchweasol  in case that helps.
Hi.  Regarding the case, if it’s glued with resin glue it is possible to soften it up using steam to allow you to dismantle it for clean up.   It’s a method I have used successfully. I borrowed the wife’s hand held steamer, worked a treat.
Thanks again both. I have ordered what looks like a #68 on eBay so we'll see how that goes. The rear door is very warped so I am going to try using a steam wallpaper stripper to straighten it out - might not work but it beats decorating the house.
Hi. Had a look in the shop no HAC MOVEMENTS several three train and two train,no good to you for parts.  looks like the bezel is 120 mm. measure the edge to edge with a vernier,to be  more accurate. Whether the glass is flat or not when the movement is in its case put a steel rule across  9. To. 3 and check the hand height. Clearance above the hands  you could get away with a flat one, no clearance you need a domed glass.
    • Case in point, I just scored a lot of 4 Timex mechanical watches for $15.50 which puts the individual watches at $3.88 each, or £3.09 (or €3.59, ¥28.08 (CH), ¥607 (JP), ₹324 ... or 0.00006 Bitcoin ) 😉
    • The 73 was my setting lever make Mike, same piece fitted to your 72. I enjoyed working on the movement, fair quality. 73 wasn't front loading,but a tight spacer ring that i had to fit onto the movement before casing up. I had to adjust endshake on the third wheel  so apart from the make everthing else was good.
    • Well it's arrived, and it's a pleasant surprise. A 11.5''' 21 jewel FHF 72. It's running (just) and looks in great condition.  It needs a good service, and new crown and strap.  It's a front loader but doesn't have a split stem. There's a small lever (visible when you remover the bezel), which when moved, frees the stem and the movement from the case (a new one on me).
    • Hi All, I'm Geoff and I've been working on/with watches and clocks since I was thirteen. My dad was a watchmaker and while he did not want me in the field as a profession, I've always maintained a pretty good working knowledge. In the '70's I kinda got pulled back into things because Quartz revolution began and he only had limited electronic knowledge. So we combined skills. He the watchmaker and me the electronics tech. Being here in NY helped because we got to know the folks from Bulova, Seiko, Citizen, and WOSIC. H.B. Freid was my Dad's teacher and I was fortunate enough to get to know him too. I still maintain a bench here at home and occasionally work on watches for friends although the hands aren't what they used to be. Not going to be working on any FHF59 or AS1012's any time soon. Oddly enough though my years working with the field taught me how to work on almost anything else mechanical and mostly electronic. Since I was the one in the family who maintained Dad's cleaning and timing machines. those experiences carried over quite nicely into the worlds of recording and audio as well as others. I look forward to the discussions and maybe still learning a trick or two. Cheers to all and nice to be here.
