Introducing Myself As Hobby Watchmaker
hello everyone, I live in Mexico city and I consider myself a vintage watch fan! I have a growing collection of vintage. My favs are bulova and Rado vintage. I have always tried to repair my watches but I never had the chance, now I am tryng to learn from Mark's videos and I'm trying. I am very delighted to be with people like you, people who love watches. Thanks
Welcome to the forum Mike, it's good to hear about your vintage watch interest. There are plenty of folk on the forum that will pitch in and help you with any problems you might encounter when you are servicing watches.
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
