Cleaning and removal of jewels
Good morning,
I'm working on a Vantage wristwatch.  The only numbers on the movement that i see are ST 92.  I've mostly been working on old pocketwatches and thus have not encountered this type of jewel settings.  Am i suppose to take the cap jewel out of that setting.  Am i supposed to take the hole jewel out of the base plate.  Or do i clean them where they currently are?  if the jewel in the base plate stays there, do i run it through the watch cleaning machine without the cap jewel setting screwed down?
On the shock setting, do i take the cap jewel out and leave the hole jewel in, with the shock spring back in place, while cleaning in the watch cleaning machine.  I couldn't find much helpful info with google, but if you know of a helpful link, i'd be much obliged.  Thank you.  Arron.
 The shock system is Kif Trio, turn the spring to remove it as you want access to the hole jewel as well, to check , clean and peg it.
Release the power through the click, remove the cock- balance assembly, remove the fork, you might want to put some penertaing oil on all screws specially the small ones.
Clean means absolutely clean, clean with brush plus ultrasonic plus any other means you know, peg the pivots, pallets, jewels and pinions.
When tearing the movement apart, take pictures as you go.
One cap stone plate has obviously got loose.
Rgds
Edited by Nucejoe
2 hours ago, arron said:
Good morning,
The two parts that you have indicated are end piece jewels. These act like  capstones over the holed jewels underneath. Remove and clean separately from the plate. I'm assuming the one ringed is from the watchmaker's side. The shock setting for the balance  as joes has said uses a kif design and should be taken apart and cleaned.
Good morning,
Something is broken , can you see where ?
All those replies are very helpful.  i would like to seek clarification on the jewels.  the jewel in the oval is the cap stone.  am i suppose to remove that jewel from the small plate it is in or just clean both pieces together.
the jewel in the rectangle is the hole jewel.  do i need to push that jewel out or just clean it in place.  if it stays in place do i need to re-install the cap stone plate before running it through the machine--do i need to worry that it will fall out otherwise.
I had not noticed that broken spring.  At some point in the day i did notice what's on the attached picture, but because i have at least four disassembled watches on my bench i didn't know where it came from--i thought it was a complete lever from one of the setting works.  Well, now i know.  Good thing i have an identical Vantage watch so i've got a spare part.
John, thanks for the reminder to check that database.  i know it's there but i seldom remember that it's there.  Arron.
Yes, the jewel in the removable plate is the cap jewel.  Do not remove the jewel, clean both together.  You can clean it by hand using your solution and a paint brush.  If you are working on more than one watch, keep the parts separated.
Hi arron, the capstone jewels in the endpieces should not be removed. Without a jewelling tool would not be easy besides. I clean them separately and reinstall them during reassembly.
9 hours ago, VWatchie said:
Can anyone answer that question? What price do you get?
Well spotted watchie, i seem to think rehajm also had it. You can split the winnings of a balance staff of your choosing 😆.
2 hours ago, oldhippy said:
If you have a good cleaning machine there is no need to remove shock systems.
What would be "a good cleaning machine"? The only argument I previously heard for not taking the shock systems apart when cleaning in a cleaning machine was to protect the hairspring and staff pivots from damage/wear and then clean the chatons and cap jewels separately. However, I was later told by or read a post by @nickelsilver that there were no risks in removing the chatons and cap jewels before putting them into the cleaning machine. And, that's exactly what I have been doing since and never had a single problem with damage/wear. Quite the contrary, it seems to be an efficient method for getting them really clean.
I find it hard to believe that cleaning shock systems in situ in a cleaning machine will be as efficient as taking them apart before going into the cleaning machine, but I'm open and interested in hearing more about this!
I do the same as you @VWatchie with the balance installed and chatons and cap jewels separate.
I was always surprised in Marks videos on WRC that he didn't remove the jewels, and only after the cleaning machine did he remove, clean, and oil the cap jewels.  It's not the cleaning of the cap jewels I'd be worried about (as I always do a final check and clean by hand if necessary), but I'd be worried that the balance pivots would not get a full clean.
I'm the same watchie.  I think the more surfaces that are exposed the better the cleaning method is. If the shock assembly is intact there are edges and joints that cant be reached and flushed out throughly I suppose it all depends how good your cleaning machine is, it cant take anything apart though
A good cleaning machine would be one that you do not have to disassemble some jewels like American pocket watch Jewels you can keep them together. Which is rather nice because usually the screws are all stripped and that would be a pain to deal with. On the other hand if you're dealing with something modern that has Incabloc even with a nice cleaning machine I would still take them out. Then you can put the balance wheel with its bridge back on the main plate without the jewels and the balance pivots are protected Even without the jewels. Especially good with etachron systems Where it's inconvenient to remove the balance from the bridge anyway.
So you want an outstanding state-of-the-art modern cleaning machine. With unfortunately a undesirable price. Uses vacuum to move the fluids around and it keeps the chamber under a vacuum during the cleaning process. This means all the little bubbles of air that's trapped like between and stones is pulled away. Two separate ultrasonic frequencies very very nice. Just really expensive fortunately I didn't have to buy it as it's where I work we have one and yes it does do an outstanding job of cleaning.
https://youtu.be/Wcc_Bk7DO4k?si=nX65yriRuLFPxqdR
But that wasn't really the answer you are seeking was it? The real question would be able with an ultrasonic watch cleaning machine how far will fluids penetrate if you have and stones? Some of those are actually designed for cleaning but most are not. If the lubrication is organic then they basically still have to come apart. Or even with the fancy machine up above if you end up with a metal fragment no I don't know how it got in their but there was a metal fragment once on a balance jewel assembly I had to disassemble it is no way a cleaning machine can get that out.
I have had many watch cleaning machines. I must say this L&R VARI-MATIC WATCH CLEANING MACHINE was the best when it came to cleaning have a built in ultrasonic in the cleaner was a big plus and it was automatic. They are very old now but I wish I still had it.
When I was in school that was one of the cleaning machines they had. Then yes I would agree this is definitely an outstanding cleaning machine. But the reference to old is there anything really old In watch repair? The reason I make the reference to old is if you do a search for L&R VARI-MATIC  You'll find references to people restoring of them is a complete user service manual out there there's YouTube videos. So they may be old but there's still in use. Although I do find it quite fascinating that the hydraulic system is still working after all these years or the ultrasonic for that matter. My understanding is the ultrasonic transducer gets unhappy if you don't keep the fluid level up high enough and you risk Burning out your transducer.
2 hours ago, Nucejoe said:
 How can a jewel under cap stone be checked?  where there is a cap stone, it must be removed to see the hole jewel.
 A 48hrs soak in CocaCola wont cost anything and you'd be amazed with how easy screws unscrew its specially helpful with little screws.
Do you receive any commission for endorsing their product Joe.  Any difference in the results between full fat or skimmed, flat or fizzy ?
    • Update, I discovered that I could change the mainspring by removing the arbor and sliding it out from between the front and back plates. So I put a new mainspring in. This it what I  get over a 7 day period After winding                                          amplitude is 1 1/2 turns plus a few degrees.        ie just over 1 1/2 turns. 1 day after winding     gained 1 sec      no amplitude check. 2 days after winding   gained 1 sec      amplitude 1 1/2 turns        i.e. it lost the few extra degrees 3 days afer winding    gained 3 sec     no amplitude check 4 days after winding   gained 5 sec     amplitude 1 1/2 turns        i.e. unchanged 5 days after winding   gained 7 sec     no amplitude check 6 days after winding   gained 16sec    amplitude just over 1 1/4 turns 7 days after winding   gained 24sec   amplitude 1 1/4 turns. From  Based on video inspection, I am getting full pallet lock. So, my data seems to be at odds with the statement "swing of a balance wheel has nothing to do with the rate". However, I have noticed the banking posts are not controlling the lever position on the right side.  I may have some work to do here.
    • I can't tell whether or not some stem is stuck in the crown, I  think so though.  If the crown is stainless steel you could try alum to disolve the stem of try drilling it out. If all else fails, buy a new crown.
    • Does anyone use the x5 eyepieces,  when i use them on my different amscope , the magnification changes to x5 but the field of view remains exactly the same as the x10, so nothing gained. The optical lenses can't be swapped out or at least they are not available as far as i know.
    • I think maybe we're all a bit dim @ManSkirtBrew 🤣 99% of the time I'm working with the 0.5X Barlow, so mags from 3.5X to 22.5X. When I need a close up of a pivot or jewel, I take the Barlow out, and even put in the 2X Barlow, but it's a nuisance. So like you, I had that D'oh moment, why don't I just use 20X eyepieces (WF20X/10). They take seconds to change, and you keep the working distance. The only downsides are lower field of view, and less brightness.
    • At the lowest magnification, I can just get all of a normal wristwatch size movement in field. For some things it's too much magnification, but the nice thing about the eyepieces is they only take seconds to swap in and out. I'm genuinely surprised I've never read about anyone else doing it, to be honest.
