Lépine Calibre V pocket watch movement.
I am working on a Lépine Calibre V pocket watch movement at the moment. In most respects it is in good condition despite it not being a high quality watch. My problem is with the spring barrel. The spring has 'hole' ends. The centre arbor is steel with small steel pin acting as the spring anchor. On the inside of the spring barrel the outer end of the spring was anchored by a small brass pin which due to decades of pressure from the carbon steel spring had worn away on the side where the spring made contact so that even slight tension on the spring caused the end of the spring to slip over the brass pin. De Carle says simply to replace the pin but gives no instructions on how to do it only saying to angle the new pin slightly backwards. Anyone have any ideas on how to do this? The spring itself is in poor condition and I am going to have to replace it but I am toying with the idea of replacing it with one that is of the same length, width and strength but with "T" ends instead of just a hole. This will mean drilling holes in the spring barrel and probably the barrel cover too for the anchoring to take effect. Does anyone have any suggestions firstly about replacing a pin or failing that the wisdom of modifying the spring barrel to take a spring with different ends to the original.  Thanks in advance. Harry
Welcome Harry. I have to get over your profile name first before i even start to read your post haha.  Just call me Zaphod 😄
3 hours ago, nickelsilver said:
Often a tongue end spring will hold on a hook that's too worn for a hole end. It would be worth a try before starting to machine things. And the tongue end is far superior anyway.
I would definitely agree with trying this first. Trying to machine things to hold In a barrel barrels can be quite a pain times.  Although it still would be nice to have a photograph
7 hours ago, Slartibartfast said:
"T" ends
The problem with this is you have a very visible watch and now you're going to see a hole In the barrel visible in plain sight.
Which one of his books are you looking at?
Practical Watch Repairing.
Having mulled over the problem and taken on board what members have said, I had another look at it tonight with a clearer mind and have drilled and tapped a 0.4mm hole  through the barrel wall at a slight angle and threaded a piece of steel wire to 0.4mm and screwed that in with a slight protrusion to act as a hook. It seems to hold. I will need to file the end of the steel wire so that it fits into the hole of a new spring then cut off the excess on the outside of the barrel and smooth it down to the level of the barrel wall. I am thinking I might use a tiny amount of loctite on the threads to ensure it doesn't unscrew but maybe this is going too far? Thank you to all that made suggestions. I am finding my way through all the forums here and there is so much information and I hope I can contribute as well as learn from everyone. Cheers, Harry
20 hours ago, oldhippy said:
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
Thank you for the welcome.
    • Hello WRT members I started a project 4years ago printing straps for seiko model 5M42-0E69. This because the strap wasn’t produced anymore and i needed a strap for my father’s watch that come to my possession. I found someone who was willing to make a computer drawing and than he started printing and worked out well. To build up the metal caps you need to have some patience but it worked.  He fiets printed a prototype in red.
    • Hello a nd welcome ro the forum.      Enjoy.
    • I went with GBP as you guys started it off and $4.04 adjusted for inflation.
    • Great help for me - thank you all. If the hairspring has been shortened, it must have have even tighter coils than it does now and they all look utterly concentric but nevertheless I'm not leaning further towards that explanation. For me, vibrating a new hairspring would be far from easy - I wouldn't know where to start.And if a new contrate wheel has been cut and mounted, it's been done very skilfully, leaving no obvious telltale signs. Cutting and crossing out contrate wheels takes skill, too, so a bit of a last resort. and why would the he have cut 70 teeth if the existing one had 75. The platform certainly looks original to the clock but I cannot rule out the possibility that it has been taken from a similar period one (with a different tooth count). It was produced by Soldano (who supplied Dent) and the movement is by Hollingue Freres (who worked for Drocourt) so it's a nice small one (not a miniature) but I have to say that it does look like it has been worked on by someone with a hammer and centre punch instead of a bushing tool. The history isn't know - the current owner has never seen it working. I completely dismantled it again at the weekend to make the tooth count but when I've figured it out, I'll take some photos. But for now, I think I've reached the end of the line.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  You might find this helpful. 704789946_TZIllustratedGlossary(2).pdf
