Setting wheel chamfer
Advice please.
Am I correct is assuming that the setting wheel, when it has a chamfer, always has the chamfer edge placed down toward the sliding pinion?  The flat edge always to the top for contact with the plate that usually secures the minute wheel, hour wheel or other part of the keyless works.
Ross
1 hour ago, Nucejoe said:
Thats how my common sense says it should be, yet I seen set mech working fine with set wheel installed upside down and no sign of wear.
I always set them with the chamfer down. Some movements work fine with them either way, but I recently rebuilt an Omega and found the hand setting very stiff and not smooth. I found that I'd put the setting wheel with the chamfer side up - turned it over and all was well.
GuyMontag, I am beginging to doubt my common sense now.
By intution one concludes , the chamfer is there to improve chance of mesh with the clutch.
You don't believe me    !!!       ask Ross , he knows.
What is odd is that the 11AOACB and the 11ANACB are basically the same movement with quickset date added to the 11AOACB and pretty much everything else interchanges. But the 11ANACB the tech sheet does not call this out for the  setting wheel and every 11ANACB I've worked on had both of the setting wheels with the beveled edge facing down 🤷‍♂️
Edited by GuyMontag
Sorry for the anecdotal evidence, but whenever I have finished a watch and the time setting seems to grind, or has that 'gritty feeling' I have always found that the chamfer is facing up, when changing this things always seem smoother. I have never experienced the opposite so now I always put chamfer down, which aligns with most of the advice on here and many of the watch videos I have seen on line. I suppose there will always be exceptions to this rule, but I would think if you always put it down you will be making the correct call 99% of the time.
9 hours ago, GuyMontag said:
The tech sheet for the Bulova 11AOACB calls out that of the two setting wheels, the one that meshes with the sliding pinion goes beveled side UP:
There's something else that is unconventional with Bulova's guidelines. Anyone else spotted it?
  • Confused 1
1 hour ago, mikepilk said:
The 'hairspring does not move freely .... but leans against the regulator pin'.
I knew that. Well, I do now that you've told me. I was just testing you...... Isn't it funny that something becomes obvious when someone points it out?
Edited by rossjackson01
grammar
I did see that when I read the tech sheet but I have to admit that I don't follow it. Same with their advice on how to oil the top pivot of the sweep second wheel. which doesn't make sense to me.
    • We think about these preps as "one-dips" partly because they are terrific solvents but also because the parts they are used on are often cleaner in general than many other parts. But old oils petrify, and even something like B-Dip can't clean up over-soiled parts without some extra effort, as mentioned above. There is an intermediate step during cleaning where the solvent can partially dissolve tarry residues so they have a more liquid varnish-like consistency, and that could well be what you are seeing on the coils after two washes. I wouldn't worry that your B-Dip was contaminated before you used it on this hairspring, but it I wouldn't re-use that aliquot AFTER this cleaning!
    • Welcome to the forum, enjoy.. Normally if a hand wound watch does not fully wind ie just keeps winding there is an error with mainspring, either slipping around its winding arbour or the mainspring is broken.
    • Most all my 404 candidates are coming from swap meets and "antiques fairs". One more $4US plus battery and elbow grease. Unnamed digital on a decent ss bracelet. Gains 10 seconds a day so not that accurate...
    • I voted.for the 6.99 assuming £, which works out to $8.74US at the current exchange rate.
    • £4.04 originally worked out to $5, or thereabouts accounting for currency fluctuations. Inflation calculator from 2020 (when the thread was started, though not when Andy coined the term) says we're looking at $6 currently. What currency is the 6.99 inflation adjusted figure cited in the poll? $6 may still seem restrictive, but don't forget that's part of the point. It's a challenge. Thrill of the hunt and all. Diamonds in the rough. Also, and my personal angle on the game, a fun and inexpensive way to learn watchmaking skills.
