Where'd It Go?
Hi all,
For those of you new enough to watch repair to still lose small parts on the floor, I recommend this little demagnetizer...£1.99 from Maplins.
It's not very reliable as a demag tool, but it is excellent at picking up screws etc. Just pass it over where you think the part might be, and the magnet is strong enough to attract things off a carpet. The beauty of it is, you can feel the tiniest screw when it hits. Only today I found a calendar spring, so although it's raining, I'm cheerful!!
Hope this helps someone.
Frank.
Get a magnetic knife rack thingy....I bought one around a foot long but now wish I wasn't so cost conscious as the longer one would make sweeps under furniture easier.
You should have a demagnetizer if you use magnets around watches..
Anil
I used to brush the floor a lot, sometimes I couldn't find the **BLEEP** thing, or in a few months it would be staring me in the face. Its part of the job having to sweep the floor looking for a part.
Just had a small flat spring go and spent at least an hour with a strong magnet and very sticky tape.  Covered the whole floor even cleared off my workspace and checked all the boxes etc on it to no avail.  Decided to call it a day and carried on assembly as it is only a practice movement I never got around to play with.  Wondered why a small wheel wouldn't sit properly only to find the spring in the vey small gap between the barrel and the plate.  Goodness knows the odds on it getting there, I think I would have had difficulty fitting it myself !!  Sad maybe but the feeling of success is great !!!
I use a round magnet from and old speaker to find my parts on the floor . I put it in a plastic sandwich bag and when I'm done sweeping the area , usually an area larger than I thought it might be , including some low window trac nearby , I hold the magnet and bag over a clear area on my work bench and remove the magnet from the bag and any metal parts fall onto the work bench .
  I will sometimes turn off the room lights and use a flashlight down low to the ground and it will cast shadows of any thing on the floor and reflect off of metal parts .
Anil
Thanks for the magnetic knife rack idea. Ordering one now [emoji1]
Sent from my GT-I9505 using Tapatalk
I would wrap that in white paper for the following reasons..
1.Helps parts to stand out. I found it difficult to spot some metal parts against the dark background.
2.Prevents parts from getting into the crevices.
3.Once a part sticks to the magnet, it is quite difficult to pry it off, imagine trying to pull a click spring, for instance, off that magnet. Paper will have some give to it, allowing you to get your tweezer under the magnet.
Apart from that, keep it away from other watch stuff (mine stays on the floor) and have a demagnetiser handy!
Anil
Anil
Anil
Anil
Thanks, great advice re the white paper. Looking forward to a big treasure find when it arrives. I'll probably get at least 10 click springs lol
    • Hi it depends on the watch. The ones with the day date complications  dial dots are not really any good as you have difficulty getting the clearance between day date wheels a the dial.  Dial feet can be fitted no problem, there are several options, the cheapest is to mill out where the foot is and glue a new foot on. ( available fron Cousins UK ) mterialhouse . Or solder on a new foot, only problem with that is you need great care not to mark the dial. I use a DIY. Dial foot machine works no problem.
    • If everything is inside them, then once restored and keeping time the oris could be worth 20 -30 each, I've paid a lot more Oris date pointers in the past. Bought this last week for a quid at a carboot sale. A cute little Smiths made in England alarm clock. The alarm didn’t function properly because the movement wasn't fastened in. But it runs perfectly now, the previous made a bit of a mess of the dial but i still love it. For the Smiths lovers here's  a picture of the inside before i case it up again. Still with it the original Jewellers box.
    • The canon  pinion height must match the one you are removing, the physical size of the movement if it’s the same as the one removed should fit ok. The bogey hole is the height  to maintain clearance from the crystal
    • I’ve come across this sort of problem. The Bergeon universal winders aren’t always universal.    Options are: Track down a movement specific winder Hand wind it Buy a new mainspring - probably the best option in my view.    I’ve been thinking how to invent a winder that uses the actual barrel arbor. Haven’t done it yet…
    • I am just in the middle of sorting out a Seiko Quartz Watch with broken dial feet and have gone with dial dots as the owner does not want to spend too much money on the Watch repair, so just wondered what forum members thought of dial dots in general?. I will advise the owner when I hand it back that dial feet replacement would be the better way if it ever became an issue. Many thanks.   Jon
