New to group
RadioK9HYF
Well, I'm green to this and any groups and new to the hobby.  I am into the Watch-Making hobby for about 2+ months and just got into  Clock-Making about a week, my daughter in law had a broken mantle clock in a box and asked if I could rebuild it but don't change its appearance "just put it back together and make it work".  So who could turn that type of request, so now I'm in the watch and clock business.
I've spent about a week gluing the case back together and ordering parts to repair the movement as I discover issues and deficiencies.  The clock is a Seth Thomas and appears to be about 100 years old, there is no movement identification, just the ST logo, and 8 1/4 is the only other stamp on the movement.  The thing that is apparent to me is the need for a main spring winder, since the Ollie Baker seems to be a simple design and the winder seems to be unavailable, I'm now trying to find the plans for one so I can build one, I've got a lathe and a milling machine os it does not look that difficult.  The only thing I can't make out from the videos on YouTube is the ratchet gear.
Other hobbies, Amateur Radio, Flying, Shooting Sports, Cooking, Looking for a new best friend (my wife passed away last year), recovering from a broken leg, and just staying alive.
By the way, my name is Michael W. Smith, and that's all for now.
Hi Michael and welcome aboard!
have you looked into the "All Things Clocks"  forum yet? There is quite a bit of info there on clock mainspring winders including copies of prints of DIY winders. I put one in there myself. good hunting and good luck!
I answered your email too.
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
