Ugly Watches
2 hours ago, HectorLooi said:
Here's another one from the same seller.
https://www.ebay.com/itm/285005245166?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=ax2ublgDQPK&sssrc=2349624&ssuid=v36TsHWBSw-&widget_ver=artemis&media=COPY
Not so good for radiation protection but it doubles as a fidget toy.
What I imagine James Bond's gadget watch would look like IRL.
Perfectly readable!
EDIT: Is that a toothed wheel on the left? Holy painful imprints batman.
Edited by lexacat
  • 7 months later...
On 9/14/2023 at 12:18 PM, HectorLooi said:
I just found another beauty on AliExpress.
I'd be worried about that one decorative gear on the bottom digging into my wrist if I moved the wrong way.  Other than that, it looks kinda interesting.  It reminds me of the fuel caps on Edwardian race cars.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
