Complete newbie
Argon
On 11/8/2022 at 11:05 AM, watchweasol said:
Hello and welcome to the forum,  the Seiko 7009A is a long time sacraficial time piee plenty of parts to be had.  I have attached the service sheet for the Seiko and a couple of others  which may be handy.
277_Seiko7009A (6).pdf 182.83 kB · 1 download 1612608791_ToolsfortheHobbyist (2) (1).pdf 371.51 kB · 1 download TZIllustratedGlossary.pdf 4.2 MB · 2 downloads
Thank you so much, this is such a great welcome gift! I am slowly getting the most important tools ($$$ painful...). As for the Seiko 7009A, I am fighting to fit the wheel bridge properly, but I hope I'll make it. Thank you again!
Hi  the main criteria is to take your time and not to rush,  Lay the bridge on top of the wheels pop in the screws loosely just to hold the plate in position with no pressure and gently adjust the wheels untill the pivots drop in to the jewels (make yourself some tools for this). Apply no pressure when you think they are all in  check the end shake ( do they lift and drop) easily aaaaa0 then tighten down the screws slowley checking the wheels as you go.   best of luck.
Another great thank you, @watchweasol! You gave me the encouragement I needed; I will follow your instructions and we'll see! I also wanted to thank you for the "ToolsfortheHobbyist" PDF, I found it extremely useful. Since I am just dipping a toe in the water, I was also concerned by the costs of lubricants. Here in Germany, where I live as expat, I found a "Dr. Tillwich" Oil... much cheaper than Moebius; I am giving it a go... I am just practicing on almost junk watches anyway...
7009a.thumb.jpg.1b9cfd12e3fd41617d9a3cb3dff78163.jpgDone! Thanks again...
Well done  patience is a friend in watch repair.   A stiff needle mounted in a handle works well for poking the wheels also if you get a good stiff needle and stone the eye back so you have a "V" shape again mounted also acts to push the wheels around,  cheap to make easy to use.   enjoy.
    • Never seen that but yes very practical Hector
    • Welcome, Simeon! I'm into Soviet watches too (not the political system, and yes, I am able to make the distinction, unlike some). They offer amazing value for money. I like your "Big Zero" profile image. It's a true classic and I have one of those myself. I noticed that the hands aren't the original. Not that it matters a lot but here's an interesting article about the Big Zero if you haven't already seen it.
    • I was thinking will the gasket stretch at all to match the desired size.  Did i also deduce that the original gasket is thinner (0 .5mm ) than the cousins gasket ( 0.8mm )  could that just be an effect of you measuring the case for the gasket size  H  ?
    • if we look at and understand why steel becomes magnetised and unmagnetised then its possible to work out why some devices are better than others. Simpy it is a parallel alignment of atoms , electrons within a material caused by external magnetic fields. Different magnetic fields cause different alignments and non alignment of atoms. Fields by AC currents are changing atom direction approx 50 times per second ( 50hz ). As a material is drawn away from a demagging device the field is becoming progressively weaker while also changing the material's atom direction having the effect of returning their random directions ( demagnetising ) . To improve on this demagetising effect, try changing the material's orientation as it is drawn away.  Fields caused by DC currents have the most permanent magnetising effect as the currect is flowing one way only. A good demagger would produce random magnet fields and disorientation of the material's atoms.
