Newbie here from Texas
shorty
35 minutes ago, shorty said:
IMG_20220904_145424271.thumb.jpg.8e470282bb63d3faf69dcca2d3c5853d.jpgIMG_20220904_145441237.thumb.jpg.fb1a5e7c77670df5272d0a54d67bab7e.jpgIMG_20220904_145428364.thumb.jpg.e39f2b9e269abeb80d4ece4d233238c8.jpgLocated in Texas.  Found an old bulova quartz clock and just has two wires coming out of the back.  I tried a 9volt and a 1 1/2 volt battery and nothing happened.
Hey fellow Texan!
I am not familiar with this clock, so I am offering a SWAG.
Before doing any more power tests, I would check the continuity of the coil. Next I would look for a switch that is closed by the rotation of the pendulum. That switch, if it is there, would close the circuit through the coil.
It may not use a switch but instead there could be a magnet in the pendulum that induces current in a coil (not present in what you show) that, in turn, energizes the upper coil to give extra energy to the pendulum.  I would imagine a simple transistor circuit to do this.
______
After looking again at your pictures, it looks like there is a compartment that is in closed. Maybe the "intelligence" is in there, and maybe you just need a power source as you suspected. Can you open the copmartment and show us?
BTW, I suggest you move your question to the "all things clocks" section of the forum. You will likely get more visibilit and response.
Here, we like to learn a little bit about you, etc.
______
Sorry for my stream of consciousness...does it say "quartz" on the face of the clock?
Edited by LittleWatchShop
is the word quartz found anywhere on the dial or did you make the assumption that it's a quartz clock?
usually electric clocks do not run on 9 V batteries because it has such an incredibly short life.
by the way this theory is conflicting with the original quartz clock.
but I do tend to agree with the theory that it's not quartz I've snipped out a section we need a much much better picture of this. looks like a coil some insulated components no circuitry, sets hidden in the base someplace which also indicates probably not a quartz clock.
bulova
I'm assuming it says Bulova on the dial but in your pictures I can see hugo hettich?
    • I wish that was the case. The Aegler movements used in the early days by Wilsdorf & Davis (for brands like Rolex and Rolco) came in several sizes and without designated calibre numbers that survive.  They become a bit easier to identify during the 1920s. Below is an Aegler-Rebberg, 25.74mm in diameter. It’s from a woman’s Rolex wristwatch. Stamped Rebberg and 500 on the dial plate (but it isn’t a Rebberg 500, it’s the wrong size).  I’d be interested if anyone can identify the movement.  It is based off the Aegler Nr.1, circa 1903, but they based many many calibres of different sizes on it. The closest I have to a positive ID is the  ‘Rolex Nr.50’ circa 1917, but no dial side images or movement sizes are available in the references. There are identical looking movements in many sizes.  The 25.74mm of this movement is a particularly strange size for the era, it equates to 11.41 lignes.      Best Regards, Mark
    • It looks like this movement comes with a number of different shock settings. Emmywatch shows that it comes in versions with no shock settings, 'Incabloc', 'shock resist', and 'Supershock'. Perhaps the different settings position the impulse jewel/roller table in a non-ideal position relative to the pallet fork/guard pin. Are you able to check under high magnification if the pallet fork and roller table are able to operate without any interference? Just for fun I took a look and I have one FHF 70 in my collection, a West End Secundus with a non-shock protected FHF70. I had a note with the watch that said, "Movement is stamped 'FHF 70', but the FHF70 looks to have sub-seconds instead of center seconds movement (??)" but that a google search turned up both types for this movement. EDIT: I just took a look in my parts drawer and I have a few of these movements, both in center seconds and sweep seconds, but they all are non-shock protected.
    • Any info on this watch would help. I know that it's sterling from London but I could not match the o letter date or make out makers mark.  Is the movement maker Camberwell or Lamberwell?   If I give it a twist it will run for about ten seconds.  $45 yard sale find.  I don't think that I want to service a fusee.  What quality is it?
    • Hello As I am learning, does anyone have any recommendations  on Repair and sourcing in Gold Coast, Qld, Australia ? eg old Seiko coil 4002920 Thanks. Cheers, Ken
    • Is this what all you're looking for?
