Omega 268 Service And De-Rust
Excellent tuition as always Mark.
Like clockboy I am curious about the rust treatment you prefer. It appears that you re used the stem so was it chemical or elbow grease or a bit of both.
Cheers,
Vic
Edited by Vich
Great job Mark, incredible finished result. Do you use Evapo-Rust or bicarb
No - I don't like using chemicals if possible. I go over them with a fibreglass scratch brush. The exception is the barrel arbor which I polished back up on the lathe. BTW - the watch is going extremely well.
I use the glass fibre scratchers always a bit awkward on small parts but very effective. Often wish that someone would make a glass fibre "scratch " wheel to fit my dremel.
 Cheers,
Vic
Oooh... I don't think that would be safe :) the little fibres are horrible - would be like mounting a cactus to the dremel. I have to say though - the Scotchbrite wheels are really good for the pendant motor/dremel.
http://www.cooksongold.com/Jewellery-Tools/Scotchbrite-Pendant-Wheel-prcode-999-ACR
Just make sure you use eye protection as I found to my immense discomfort when I first used one!
I couldn't do without my Dremel but like George I always finish off by hand
(just realised what I have written - please resist lads I was actually trying to be serious for a change)
Cheers,
Vic
  • 4 months later...
Happen to be working on a PUW1261 with similar rusting of the stem into the clutch wheel and winding wheel.  I cleaned off the worst of the rust with a fibreglass pen (well away from my other watch work as the small fibres get everywhere!) but could not budge it even after soaking in deodorised kerosine (BBQ lighter fuel) for a few hours. I then left them overnight in Plus-Gaz and they came apart with a good tug.
I cleaned off the worst of the rust again with a fibreglass pen . I then soaked overnight in Kurust (which I used to use on rusty car panels!) which converts all the rust (Ferric Oxide) into Ferrous Phosphate which is like a protective layer.  The Kurust contains phosphoric acid which converts the rust, (I gather well known brands of cola also contain phosphoric acid and will convert the rust but not tried!), the parts should be thoroughly washed in water and dried after treating. The reason for doing this treatment is to prevent the rust reforming as it surely will if microparts of Ferric Oxide are left in the material without being converted (of interest is that most greases contain some water and so can restart the process on their own if not serviced regularly!).  The phosphate left after treating will prevent further rust formation. The phosphate layer is mid/dark grey and can be cleaned off using the fibreglass pen again and/or 1200/2500 wet and dry to get back to a bright finish with the ingrained phoshate still left.    I finished off the square hole in the clutch wheel by applying a paste mix of diamantine and oil to the stem and working it until it was nice and free and the stem part polished up a bit, then cleaned off with a wash.  All parts where then put through a normal clean cycle.
    • Why cut the paper, cut a square around the image and grind to it.
    • I did try that last time Rich , i traced the image from the Bestfit book which is the actual size. But its more difficut to cut the shape from paper than it is to grind the steel to shape. This way is pretty easy and the final shaping is done when fitting the part. There are a couple of things i will do differently next time, clamping the 2 pieces together with a drill press will help to hold while scribing the shape in. This was a bit tricky having only one hole, if using the pins and cork the drill size needs to match the pin diameter so there is no movement at all from the template. This movement hasn't finished frying me yet, damaged thread in the plate crown wheel hole and two rubbed in cracked jewels, thats gonna be much more fun.
    • 👍 Whats not to follow OH ?  You're every inch a pro and a true gent, i always enjoy reading your answers even some of the clock stuff that i dont have a clue about.
    • Could you print the image either enlarged or reduced to the same size as the actual part and then glue it to the steel.
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
