Omega 268 Service And De-Rust
This nice Omega came in with a seized up keyless work. The crown could not be pulled out to hand set position and the watch could not be wound. I immediately suspected rust.
Getting the movement out of the case was a challenge because the crown could not be pulled out. But luckily I could unscrew the crown from the stem as the stem was seized.
With the movement out of the case, I can see evidence of rust. Time to get stripping (the watch).
First challenge was unscrewing this dial screw which was rusted in place. A bit of oil and some gentle persuasion and it unscrewed.
With the dial off I can see the extent of the damage which is quite bad - but not the worst I have seen.
Off with the hour wheel:
And the setting lever spring:
And this is as far as I could get. That stem was not coming out, but I have an idea! ...
  • Like 7
Well I decided that the first thing to do would be to dismantle the rest of the watch - can't risk damaging any parts.
But first I drowned the stem and winding pinion with clock oil so it could start soaking.
Then out with the balance...
Then off with the ratchet wheel - does not seem to be any power there but I can't risk it so it's a good idea to remove the ratchet wheel and click work altogether. I don't like the ring of rust around the barrel arbor bearing...
And the crown wheel...
Now I am sure there is no power on the mainspring (but I was wrong) so I can remove the pallets...
Off with the barrel bridge and surprise surprise... more rust :(
Not looking good - but it seems to be surface rust so it should come off easy. Now to open the mainspring barrel. Remember I told you I was confident all the power was released? I was wrong:
Yes - the barrel arbor was seized in the barrel and so the spring was stuck in a fully wound position!!! I have never seen that before. Time to improvise.
I thought the safest way would be to put the barrel in a polly bag and push the arbor with my fingers. That way nothing flies across the room :)
And that seemed to work well.
With the tension off I am able to get the arbor out and inspect it. It's a bit corroded...
More to come...
Mark, Geo will lend you his Bergeon Basher!
I understood that Geo broke that opening a pocket watch :D
Interesting . How are you going to get that of ? Heat ? Oil ? 5-56? Coca-cola?
A mixture of both as it turns out.
Soldering iron?
Now that's a good idea - I hadn't thought of that.
So next off is the main plate exposing the wheels. I was half expecting to find rust in the pinion leaves or pivots but all seems fine.
Off with the wheels...
A teeny bit of rust on the escape wheel pivot but luckily not attached - brushed off and left no stain.
Now back to this bugger of a stem. The oil did not seem to help...
But after heating it up with my spirit lamp, I grabbed it with my pliers and gave it a sharp pull. It came away just fine.
The barrel arbor was quite rusty so I decided to burnish it - easiest way is to use the lathe...
And it came out quite well...
Just need to clean up the rest of the parts and clean the watch now.
To be continued.
  • Like 8
Great write-up Mark :)
I think I've mentioned this before, but has anyone use EVAPO-RUST?
I've seen it used on old TV and Radio restorations, and it's amazing stuff.  It removes the rust; but doesn't affect any of the cadmium plating or even the old paint.
Might be worth a look into guys.
http://www.evapo-rust.com.au/How%20It%20Works.html
Very instructive and to the point, Mark. It's value is not only for the service but it has an amazing depth in its educational value which is very much appreciated by us newbies! Please, keep it coming!
Cheers,
Bob
PS. I wish I had a lathe and could work on it half of what you do! :)
Finishing up now...
The parts are clean. Some parts are a bit stained but they are sound.
Assembling the train...
And the mainspring/barrel...
Assembling the barrel bridge...
And the keyless work...
And with the escapement back in, the watch is flying...
So now the watch is running fine, the keyless work is smooth like silk. Now ready to case up...
It's a lovely watch...
  • Like 6
Cool Mark, I have an old Benrus with the same affliction!  Was about to ask Geo to use his Bergeon Basher but thankfully I had to step away from the watches for a few months.....    This was the first post I read since sitting back at the bench-  Thank you
Dan
    • Maybe I'm over simplifying this and I'm a little late to the discussion, but just by my looking at oil when I use it on a treated cap jewel  the oil stays in one nice bubble, but when I don't it spreads out to the edges of the jewel. I'm not sure (but could well be wrong) but the analogy of a waxed car and rain is accurate in this case, the wax is very hydrophobic and repels the water, however, the process epilame works by is a different physical process based upon cohesion/adhesion (oleophilic) not repulsion (oleophobic)  at least as far as I have read/observed. If one were to use a oleophobic substance equivalent to wax (hydrophobic) then one would need to create a donut shape to fence in the oil, however if one used such a strategy with a epilame which is oleophilic then the oil would sit on the ring of the donut and not in the 'donut hole', exactly where you don't want it. Even is the oil is smeared then the oleophilic epilame should pull it back to the center (see diagram below). Reference
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
    • If the oil drop was freely standing on an epilame treated cap jewel it could easily slide off if you knocked the watch hard but the balance pivot keeps it in place.
    • Latest 404 is this Baron which has a copy of a Seiko 66B movement in it, handy when I needed to find a replacement setting lever. Apart from the setting lever, crown, stem and new crystal (original was cracked) the watch is original. Finished result:
