AS/ST 1686
Hi folks
I’ve been disassembling and reassembling the above not really working practice movement.  All seemed OK (bearing in mind my limited newbie capabilities) until I got to the click and it’s spring.  I cannot get the click to work.  It moves when I start winding but won’t click back into place to hold the wind.
I’ve looked at the previous posting on here re the same movement and the spring looks the same and seems to be located the same.  The spring is .3mm tall as it sits in its groove.  The click has a nubbin on the centre arm but it does not engage with the spring.  I’ve taken the lid off the barrel and it looks fine to me…
I should mention that I don’t know anything re the history of the movement.
I’ve taken some photos.  Any comments that would guide me in the right direction would be greatly appreciated.
Thanks,J
If you observe the click spring, it has 1 long arm and 1 short arm. The long arm must engage the small nub on the underside of the click. Sometime the click spring is not original as click springs have wings and tend to fly away. The end of the replacement spring might not be shaped correctly and might not be engaging the nub. I've even seen one that was so short that the last watchmaker didn't push the crook of the spring all the way into the recess or else it wouldn't even reach the nub.
So check if the spring is long enough to engage the nub.
Could you get a photo of the click and spring with a higher magnification? I can't see the end of the click spring properly.
2 minutes ago, Shane said:
It's hard to see in the photo but is the long end of the spring on the correct side of the click's pin?947074304_6DF4CE58-B446-451C-97C8-C246C446716D.jpeg.a43a540ed4fcdcc839ecfa4bfe76f1683.jpg.c1f3b5f45f388586065c8f59fcaa3119.jpg
It is difficult to see but I think it's the right way round.  I think the spring is on the wrong side of the little protrusion (is there a name for it?)
Yessss.  It's going.  Ticking along nicely for several hours now.  The spring was on the wrong side of the nubbin.  I've only tinkered with three or four watches so far and I didn't know there were right and wrong sides.  It's all so dang small.
Thanks for taking the time to comment and especially thank you to Shane for marking up the photo for me (worth a thousand words....).
I'm sorry about the quality of my photos.  I was into macro photography in my twenties but now I'm limited to what I can do on my phone or tablet.
Watchweasol - thanks for the PDF.  Is that something I could find if I knew how?
  • Mark locked this topic
This topic is now closed to further replies.
    • My mentor has been using one of the Chinese clones for several years. Seems to work very well. Just put the object you wish to demagnetize in the centre of the cross and press the button. One word of caution though, the quality and QC of Chinese clones can vary a lot. You'll never know whether you got a gem or a lemon.
    • You could also use a very fine artist's brush to brush between the coils.  If you get a size 00 or even 000 that should be small enough for convenience, and with bristles so fine that they are incapable of damaging the hairspring.  Get a good one though, like Windsor-Newton or similar.  I have never had a Windsor-Newton brush shed on my art or other work.  You want a soft brush that will not shed.
    • Sounds interesting but how do you push the button if you’re holding both ends? the large current draw overheats after 3-5 seconds and the thermister triggers. A great tool for magnetizing things but I’ve not be able to ever demag anything with it because the emf is so strong it pulls the item off center (down or up).   I paid $89 bucks for it from  CAS-KER, if someone on the board wants it I’d gladly sell it for $25 plus shipping (probably US only otherwise postal costs are prohibitive). Just sent me a note offline.
    • Hi. First thing to do is measure your oil movement as the vx32E and the 43 look very similar but one is a couple of mill smaller the vx32E.  Also the canon pinion heights differ attached tech sheets for 7N22. And  VX43, check details on the sheets. 7N22A_29A_33A_42A_43A.pdf VX43.pdf Hattori VX32E - Specification.pdf Hattori VX32E - Disassemble.pdf
