OMEGA SEAMASTER.
hi all. i recently serviced a vintage omega sea master for a friend of mine and even though i had to source a part or two everything went swimmingly ; or so i thought!. after testing i gave it back and my friend was happy for a while, he even said it was keeping time with his quartz watch. then a week or two later he said the hour and minute hands would stop around the eight clock mark although the second hand kept merrily on. i took  it back and the mystery does exist. any ideas please?
always nice to give us a model number as different models conceivably can have different problems and answers conceivably could change.
23 minutes ago, gbyleveldt said:
Loose cannon pinion
usually the secondhand is moving in the hour and minute hands are not Loose cannon pinion definitely a place to look except? They usually don't get loose all by themselves so how did the setting of the watch field before you put in the case? Sometimes you might have a borderline situation where it seems loose but it seems to work and then the reality is it's to use
38 minutes ago, berniethebolt said:
any ideas please
eight clock mark
does it totally stop and then how do you started back up again? You have to set of tests this or does it just temporarily stop or what exactly do you mean? Then visit stopped twice a day or only once a day?
At least one of the things with a stopping situation is it's much better than a intermediate situation that occurs seemingly randomly.
You also want to look at your hands for some reason may be they 8 o'clock marker is sticking up too high is the minute hand hitting anything. It's where the quote I have up above any ideas please without proper diagnostics which you have to do we get the gas. Like hand hitting in the 8 o'clock marking position where the markers stuck up or something
if there's nothing visible on the dial side that you can see is a problem you can take the movement out of the case and see if the problem goes away out of the case. Then remove the hands but make sure you note the position that there in because we need to put the hands back where you found them once the dial is off. At least you might put the hands back on otherwise you can carefully look at the dial side for any kind of damage.
Does the watch have a calendar? A lot of calendars don't like to be rapidly advanced at midnight usual procedure to tell people not to advance the calendar it's always conceivable of something is broken is floating around inside their of course it would help to know which movement this is.
One picture shows the date changing though the time is only 8.30  - What's happening there ?
As mentioned above, the fact that the second hand keeps moving suggests a cannon pinion problem.
This movement has an unusual feature - the "Date Corrector" which changes the date when you pull the crown.
If not installed correctly (I didn't the first time) it can jam the date wheel
Did you install it correctly - i.e. does the date change when you pull the crown out ?
the date wheel has had it half of the numbers are missing and my friend does not want to replace it has he cant see the date anyway! as for the quickset it wont work because it has a split stem so i am going to remove the date indicator driving wheel and others and see if that fixes it!
If it always stops in the same position remove the dial and inspect the teeth of the hour wheel, minute wheel and cannon pinion for wear, distortion.
A loose canon pinion will have practically no resistance when hands are being set.
Anilv
    • I can remember in the army, doing a tactical night march and the officer leading the march had the bright ide of taping his compass (with tritium tipped hands) to the end of the barrel of his rifle so he could get a better bearing in the dark. We ran around in circles for hours until he realized that the compass was reacting to the steel of the rifle barrel. To say he was unpopular was a bit of an understatement.
    • I bought a compass to detect magnetism. The magnetic tip reacted to both magenetised and non magnetised basic steel so it became a guessing game as to whether my test subject was either weakly magnetised or dense steel. I've found the best way to detect magnetism is by using the smallest unmagnetised screw and a known piece of unmagnetised steel to test the screw and another piece of known unmagnetised steel to test the first known piece of unmagnetised and another....................... 😂
    • Ha ha, reminds me of this: "Don't go puttin' none of that stuff on my sled, Clark. You know that metal plate in my head? I had to have it replaced, cause every time Catherine revved up the microwave I'd pi$$ my pants and forget who I was for a half hour or so. So over at the VA they had to replace it with plastic."
    • Hello and welcome to the forum. Added a little help for you . TZIllustratedGlossary.pdf
    • Hi @VWatchie - I have model of this Mondaine quartz watch in my collection, just a smaller size. I bought it many years ago, new.  I wonder if  the crystal on your watch is original?  My original crystal was entirely flat.  I scratched it at one stage and replaced it.  There is a dealer located in the UK who sells replacement crystals for Mondaine on the big E - I bought mine from him.  If you PM me, I’m happy to forward the listing details - he may keep different sizes for the Mondaine range?.  The replacement he sent to me was a perfect replacement for the original.   On a side note, the Ronda movement in these is very easy and fun to work on.  They’re also very cheap to replace.  I learnt a lot about the big date complication when the smaller date wheel spring mechanism malfunctioned and the date changing stopped. I stripped down the movement and it went back together very smoothly and continues to work perfectly.  I like the streamlined aesthetic of the Mondiane line.  I also have one of their big date mechanical movements which runs on an SW200-1. The crystal on that is also perfectly flat, btw.   Cheers, John
