Advice on servicing an Atmos clock
HectorLooi
I have been watching videos on the repair and servicing of Atmos clocks and I'm intrigued.
I have so far serviced three 400 day clocks, which look very similar. I think I'm ready for an Atmos clock. So before I blow $1000 on a low end Atmos clock, I have some questions.
I'm just wondering how much more difficult is it to service an Atmos clock?
Are there any special tools and jigs required?
Can the ethyl chloride that we see being used to treat football injuries on the field be used to refill the bellows?
Any advice and words of wisdom are desperately appreciated. Thanks in advance.
Hi Hector  from what I have read about them they are a bit specialist, but that does not mean you cant repair them the working clock parts are conventional but its the atmospheric bellows and the setting up of the same that seem to pose the problem. $1,000 is a fair price to pay for a working one .
There's an Atmos specialist at the base of the canyon I live in. I paid him a visit a while back while he was in the middle of one, and the issue with that one (and he said it's a frequent issue) was the drive chain had broken. Super fiddly. How much do the broken ones go for? I imagine you wouldn't need more than two to have a complete runner.
If you take a look at eBay at the moment, a working clock is around $800. Will probably end around $1000. There are "buy it now" ones asking for $1500 too.
Non runners are around half the price. But with non runners, it could be a simple problem or a total mess.
I'll probably watch the action from the sidelines for awhile.
I don't have a list of the tools but yes there are a lot of or some special tools you  need. Ideally need a holder for the movement itself and there's a variety of other tools.
Then in addition to the tools yes you need to know how to use the tools and why the tools even exist. So these are not the kind o'clock you can just rip apart run into the cleaning machine put them back together and you're off and running. Basically the movement itself is like a really big watch and has to be treated as such. They even do things like put epilam on the plates to keep the oil from spreading over time. Then there's things like the pallet fork it has to be poised which ideally means you have a poising tool for the pallet fork.
Then you also have to be careful with the running clocks in that if somebody winds up the mainspring manually because the tank is shot I can't quite remember but ill run a long time if that mainspring is welded up. This means you to buy a running clock perceiving that it's running and working fine in several months from now find out that it's not running fine and that can be an issue.
They look simple but this is really a very very specialized item
If the bellows is leaking its a specialist job.
I know something that services these clocks every now and then and if the bellows is leaking he sends it off to a specialist in the USA for fixing.
The pivots must be perfect on these clocks for them to run.
Actually I'm not really worried about a leaking bellow. I'm familiar with soldering sealed systems from constructing heat tubes for my computers.
I'm also very familiar with ethyl chloride as I used a fair bit of it as a dentist.
Now I wait for my manuals to arrive and for a suitable bargain on eBay.
On 4/26/2022 at 5:41 PM, oldhippy said:
Ethyl chloride that's the stuff that knocks people out.
No. That's nitrous oxide. You often see the medics at football matches spraying it on the knees of injured players. It's a cold spray, it just temporarily numbs the pain.
We use it to test the nerves in a tooth and also to numb a wiggly milk tooth for extraction.
You could knock somebody out with ethyl chloride,  but there is a good chance that person is not going to wake up.
There have been cases in US schools where kids inhale the stuff for a buzz. And some didn't wake up. So now it's really hard the get the pure stuff. The stuff used by footballers has an additive in it that smells like "pig's fart".
Some suppliers didn't know this and tried to sell this ethyl chloride to dentists. GOOD LORD! We use the stuff in the mouth! 🤪
Edited by HectorLooi
Typo
Sorry I overlooked this thread!  15 years ago I got my father‘s Atmos which was not running anymore. With the help of a repair video from an experienced american clock maker (Anthony Montefusco, passed away 2011) it was not to difficult to replace the broken balance wire. Here ist the only (self made) special tool I needed to poise the balance shaft.
The documentary I gathered at that time is still available if it‘s needed.
Edited by Kalanag
  • Similar Content
    • The wheels turned fine. I set the escape wheel in the epoxy when it had just ‘skinned’ and wasn’t set, made sure it spun with the 4th wheel, and let it set.    After cleaning I assembled the barrel and wheel train - all fine. Moving the barrel the escape wheel spun freely. I put a bit of 9010 in my epoxy setting.    It went wrong when I put the pallet fork in. It wasn’t seated right (no jewels) and the escape wheel  knocked a pallet jewel out. I have no idea how to reset a pallet jewel - epoxy again? I’m not spending any more time on this one - it’s missing hands and the front half of the case anyway, and I have more watches ready to put on the bench.
    • No John, we don't want Mark to change anything, we are just scared of losing a brilliant forum and losing contact with each other.  As pointed out, this forum is full of knowledge and I for one,  consider the regulars friends. I would hate to lose contact with you and the others.   PS, this forum is really important to me.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
