Hello folks,
I just bought a used Seitz jewelling set. All in all I'm very happy with it. The condition is good and it is almost complete, but there is a problem with the micrometer adjustment. It is stuck tight and will not turn under extreme finger pressure (ow!)
Not having owned one before, is there a trick that I'm missing? I've removed the locking screw, and added oil, but no change. Before I set to with the adjustable (Engländer in German!), is this a common problem, and what is the likely cause?
You should be able to adjust it with ease. AS you have removed the screw the only thing that I can think of it must be rusted in. Any signs of rust? I hate these stuff but have you tried W D 40.
28 minutes ago, oldhippy said:
Any signs of rust?
None that I can see, but depending on the metal pairing there might be some galvanic corrosion on the thread. Good to know that I'm not missing the obvious.
11 minutes ago, watchweasol said:
this guy has just refurbished his press
I found that report yesterday, and it is the best description of the tool I have dug up so far. Better even than the official instructions. He had a problem with the two marker posts sticking, but not the screw adjustment itself, so not much help I'm afraid.
I'm not in any hurry. No doubt someone else has solved this problem before.
Got curious and took mine apart. Here is a picture for whatever its worth. Have you tried the blue wrench?
Edited by Nibbler
Blue wrench = torch. If all else fails you could try carefully heating up the main casting over the threads and then attempt to unscrew the insert. This would be a last resort option.
Supposedly, the zinc/aluminium whatever metal of your press expands its volume by corrosion, what makes the problems. It is different from the older steel body of Nibbler's tool.
Unfortunately I have no better idea than lubricating & force.
Frank
Frank
Wouldn’t corrosion in the micrometer stop cause some backlash/movement in precise measurements for jewel depth? You can imagine the micrometer dial/stop having “end-shake” due to a damaged screw thread of the micrometer.
Supposing he gets it apart, and cleans off the corrosion, yes, there will be metal missing where it once was. But the screw pitch remains 1mm and that pitch makes its own average over the number of threads engaged; if you were to measure and map the screw over its entire range you might see some diversion from one line/0.01mm, but for the short travel it might do to press in or even less adjust a jewel it will still be very accurate. The "push" is always down. Like using a lathe or milling machine with some play in the screws, you always take your cut coming up with the crank in the same direction. I had a bench lathe with screws so worn they had 3/4 turn of lash, and could still do accurate work, just always going the same direction (and over a short distance).
  • Thanks 2
It looks very clean, not likely to be corrosion. Probably dried up 50 year old grease. Try WD40 sprayed into the locking screw hole. Dropping a couple of drops of benzine also helps.
Have you tried pressing down on the 2 spring loaded index pointer pins?
They appear to be stuck too, but I expect they will be easy enough to free up, once I get the screw dial out of the way.  I've glued a nut on top and I'll leave some WD-40 to soak in overnight, then try some gingerly applied brute force tomorrow.
Thanks for all the help so far!
I have the same one without the spindle and accessories.
If you can not get it to work I am willing to part with it as I only needed the spindle to get my set complete.
That is very kind of you, and I may take you up on it if things do not go well. So far, I have been able to remove the micrometer screw from the body, but not without some cosmetic damage to the scale (clumsy use of grips) and the paint (hot air gun).
@HectorLooiyou were right on the money with the dried up grease. That's what it looked like to me, anyway. A tiny amount of residue, but  because the thread is such a precise fit, it was enough. Now I am working on the markers (stuck all the way down, with very little to grip on; the 4.0mm collet in the lathe just slips off). Any ideas? Now they are soaking in WD-40 for a week, while visit my parents.
Also not moving freely is the micrometer zeroing screw in the chromed cap. If anyone can explain how the component parts of that work, or has photos of a disassembled one, that would be a great help.
WHOA! You mean there is a zeroing mechanism?
All this while I've been subtracting the numbers to get a reading.
I thought these micrometer type jeweling tools were used to judge relative movements of jewels by hundredths of a mm, not absolute measurements? I’ve never heard of it used in this way.
Edited by ifibrin
Back from my trip today, and the micrometer zeroing screw had responded well to soaking. It came apart with very little effort, and is as simple as can be. Just two parts, the cap and the split screw. The thread is right-handed with a 0.5mm pitch.
The spring-loaded markers are still stuck. Any ideas?
The markers are out! Heat, heat and more heat was the answer in the end. After sustained contact with my biggest soldering iron (100W) one of the markers began to creep out of its hole. The other needed a bit of persuasion from the 3-jaw chuck on a power drill, but also came out without a fight in the end.
You can see the discolouration on the parts. It's hardly anything, just a tiny bit of dried up grease or surface rust, but because of the close tolerances, enough to jam up everything. Now to get to work cleaning and polishing!
Just an update at the close of this little project of mine. Here's a picture of the final article, warts-and-all. You can see the damage to the scale, and the flaking paint I mentioned earlier, neither of which affect the function of the tool, which I'm delighted with.
Something else I learned which may or may not be useful for others to know. The knurled ring on top of the micrometer screw is a separate part and a simple interference fit above the scale.
Thanks again to everyone who offered advice and assistance.
Are you going to oil the spindle and micrometer thread?
  • 5 months later...
Just for information if someone else still has trouble with stuck parts in the Seitz tool. I have the same model as depicted and the spring loaded thingies were stuck in the bottom. Just a couple of seconds in the ultrasonic cleaner and one side popped up and a little later the other one was released. I decided to give it a thorough cleaning and ran the 10 min cycle till the end. Some of the paint flaked off so be careful if you care about the finish. Well it was flaking anyway and it's just a cosmetic flaw.
    • I was wondering because of the alum idea.
    • just a reminder about this test is it's not a perfect test it's a quick test. In other words you can adjust the banking pins that are both the same and visually this test will pass everything looks the same but both banking pins can be in the wrong place. although the majority of time when people are playing with banking pins I don't put them in the same place. one of things have to be careful of is I believe some of the pallet fork measuring tools that actually give you the roller jewel size are actually size so that I get confused? What I mean by this is if you inserted a whatever size in and are always told to go a slightly smaller I thought that the gauge itself its number corresponded to give you the exact number. So a lot of it depends upon the gauge itself I think you do want the roller jewel slightly smaller because it does have to fit in the slot and it does have a little bit a play. But if it's too small you will lose energy so does have to be sized right. Oh other things to check is? I'm attaching an Elgin sheet on checking the escapement I've seen references in the past to making sure that the slot in the four corn is nice and smooth and apparently you can end up with a rough slot and then the recommendation is to polisher clean that up. Not sure how well that's really going to work even if it has been the recommendation of other reference materials. yes art full plate watches fun when they don't work. This is where it's nice to have another set of eyes sometimes as maybe they'll find something you didn't  although that can add other issues. The owner of the shop provides himself on his skills of so now two of my watches have relocated to his bench to solve problems both real and imaginary I'm sure that will get fixed eventually hopefully. But still sometimes another set of eyes might see something that you're not. yes this sort of thing can be quite frustrating. Also makes for an interesting problem unless of course you're the one trying to solve the problem that it's a Escapement Elgin setting up the escapement.PDF
    • I’m not to sure mate! I’ve sent a picture! The crown is off a Tissot 1853 automatic limited edition T115427 A GP19 moto go watch!
    • For years and I'm still using it I've been using something called SeaMonkey? It's a Mozilla product Basically outscore its Firefox plus an integrated email program. But not the same problems here a lot of times when things are upgraded they tend to be now aimed at very specific browsers like Firefox so I've had to switch to Firefox to respond to any of the messages on the group. So yes they do seem to be getting more browser specific and that may be a reason for others having complications especially if whatever you using hasn't been updated. So yes the world is getting more browser specific perhaps for security reasons. Even though I use a product that is updated on a regular basis is still has problems. So whatever you using for browser should be up to date and if is not recognized it's going to be a problem.
    • I did remember to ask at work and minor complication? Well I suppose technically two separate complications. First off glass mineral glass versus Seiko's Hardlex Glass. Don't know if other companies have their own class or not and a basic class for crystals is probably not the same as window glass it would be more transparent. It becomes obvious if you're looking at a sheet of flat crystal glass versus window glass it's definitely more transparent you can see it when you look at the edges of it window glass looks green. No idea how that changes physical characteristics other than optical. Then we also have thickness like the Seiko five's there crystals are really sick compared to other things and I'm guessing that makes things different. In the first link it talks about Sapphire versus mineral glass. One other thing is bothering me though when I'm reading this is where is the source material? What I mean by this is could we end up with multiple generations of salespeople quoting the same sales tactic or information and we don't actually know because you don't have a source reference? Let me quote something off the website it's brittle oh dear I was sad? Except it's not immune to damage it can crack where shatter under extreme force or impact. So what is the definition of extreme force or impact? Then is that more or less extreme then mineral glass?  Then regarding the price difference while back I had asked the owner where the Sapphire came from and basically wherever he can get the cheapest. So typically ordered from a variety of online supply watch parts in the US and  aliexpress China.. Then yes it does make a difference because we go through a lot of glass crystals and sapphire https://thehorologylab.com/sapphire-crystal-vs-mineral-glass-which-is-best-for-your-watch#google_vignette Then I guess one is glass not glass when it goes by another name? Hardlex Looks like it's purely a Seiko product but now I wonder if other watch companies have their own special glass? I didn't remember from past experience my favorite was people exposed to welding you can find little blobs a metal stuck to the watch case the crystal still intact but there's little burnt holes were bits of metal had actually burnt into the crystal but it was still there. Okay website below starts off with Sapphire sounds good but Apparently it can shatter easier then Hardlex. https://theslenderwrist.com/hardlex-crystal/ One other thing is what I'm reading to websites would be back to I want to see the test results? Often times weren't looking for a subject will find websites where I basically called them these are better than that by the way but sometimes I'll find websites that I will call book review websites were basically the review other websites other material and don't really introduce anything new to the subject. As I said these websites look quite nice which is why I'm giving you a link but where's the test results the definition of extreme how extreme to break a sapphire versus a glass or Hardlex?
