Hello ,
I'm a former yacht mechanic who's now landlocked and have been watching a bunch of watch repair videos over on the 'tube.
I have a few old watches lying around, and have thought about maybe giving the hobby a try since I love mechanical things.
I have a Rementoir 10 Rubis pocketwatch that's in pretty sad shape that I might have a go at. I saw that someone on this site had posted
a .pdf walkthrough, but it is no longer hosted. I have a question about magnification. What do some of you use? I have a 'watch repair set' coming just to see if I
can do it. I don't want to dump a bunch of money into tools just yet, and I also want to get a few pocket watches to try my hand at.
Welcome to WRT.
For a start, a simple magnifying loupe with a headband will do.
2Pcs 5X 10X Headband Monocular Eye Magnifier Magnifying Glass Loupe Lens Set Watch Jewelry Repair Tool Accessory For Watchmaker
https://a.aliexpress.com/_m0Kef9U
I think all of us will go through a dozen or more magnification devices and still hunger for something better. I went through simple loupes, headband magnifiers, clip on loupes, surgical loupes, etc.
I'm currently using a stereo zoom microscope and it serves me very well. But I'm looking at a digital zoom microscope for very high magnification work.
Enjoy.
Thanks for the welcome. I've gotten the Rementoir mostly apart, after having to fight the crushed housing to get what I think is the barrel bridge out. I have other issues, this thing is a mess.
On 3/28/2022 at 9:47 PM, HectorLooi said:
Welcome to WRT.
Enjoy.
I am currently using a 3.5X stereo magnifier. Awkward, but getting it done. So far.
Thanks for the intro GEC, welcome to the WRT forum! I'm also relatively new and I'm in the middle of my first service of an Elgin Grade 313 movement. If I can do it, you can too.
There are quite a number of YT videos that will get you started as will some of the walkthroughs posted on this site.
To start, I've been wearing a magnifying visor and using a hand glass. I purchased a 10x loupe but it is really for close inspection work (like looking for damaged jewels). I have a 4x loupe on the way and I may try that with a headband.
Good luck!
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
